Thread: 1998 grand prix gt
Results 1 to 9 of 9
nyydmb12 1998 grand prix gt 07-21-2009, 03:28 PM
1LoudGrandPrix Re: 1998 grand prix gt 07-21-2009, 04:25 PM
Mad Monkey Re: 1998 grand prix gt 07-21-2009, 06:32 PM
LOUDANDPROUDGTP Re: 1998 grand prix gt 07-21-2009, 06:56 PM
nyydmb12 Re: 1998 grand prix gt 07-22-2009, 11:16 AM
boobie Re: 1998 grand prix gt 07-26-2009, 02:42 AM
1LoudGrandPrix Re: 1998 grand prix gt 07-29-2009, 12:12 PM
stlmo_gtp Re: 1998 grand prix gt 07-26-2009, 03:39 AM
nyydmb12 Re: 1998 grand prix gt 07-27-2009, 10:15 AM
  1. #1 1998 grand prix gt
    SE Level Member nyydmb12's Avatar
    New York
    Me and my friend are putting new speakers in his grand prix. Would the best way to replace the rear speakers to hook the new 6x9s to the wires that went to the stock 4in mid range speakers.
    2004 grand prix gtp
  2. #2 Re: 1998 grand prix gt
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    well on the 97-03 you have to take the whole backseat apart to get the speakers
    should just take the 6x9 out and put new if and then do the door speakers
    also put more info as that would help
    like aftermarket deck what other mods?
  3. #3 Re: 1998 grand prix gt
    London Ont, Canada
    there is a thread about rear speakers
    http://www.grandprixforums.net/f41/r...ers-10313.html
    in there should detail what i did
    but heres the rundown
    -seat out
    -speakers out
    -desoldered factory connector
    -attached to new speaker
    - reassembeled
    -enjoyed lol
    and yeah dont just do the rears, do the fronts as well you can tell the diff
  4. #4 Re: 1998 grand prix gt
    Houston, TX for now
    Are the stockers Bose and hooked up to the amp? The amp runs an odd ball ohm. If you have an after market deck run a new set of wires from the deck back to bypass the bose amp. They will sound better and be easier to control the volume on.
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  5. #5 Re: 1998 grand prix gt
    New York
    Well the install is done we had front speakers too I was just curious about the wiring configuration for the rears because he has the 6x9s and the 4in's in the back so we hooked the 6x9s to the factory wire that was going to the 4in speakers and it sounds fine. The front speakers we replaced we just had to slightly modify the plastic bracket because the speaker was a bit larger. But all said and done even with the stock head unit it sounds great....and I'm 98 percent sure he does not have the monsoon or bose I didn't see an external amp and there isn't any indication of their name being on the system like in my 04 grand prix.
    2004 grand prix gtp
  6. #6 Re: 1998 grand prix gt
    SE Level Member boobie's Avatar
    miami
    I have a 97 GTP and I had to take out the hold back seat to get to those
    6x9 I replaced them with Pioneer 5ways the best 6x9 I ever heard in
    my life
  7. #7 Re: 1998 grand prix gt
    Cedar Rapids, IA
    Quote Originally Posted by nyydmb12 View Post
    the external amp is in the trunk if i remember correctly and is about middle and is 1.5in thick and 3in wide and about 4in long
  8. #8 Re: 1998 grand prix gt
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    yea changing those rear speakers is a PITA, but it gets easier the more you do it, i have had to take mine old twice or three time stockers blew replaced them then the other ones that some weird problem, finally installed some infinity kappas
  9. #9 Re: 1998 grand prix gt
    New York
    I plan on doing an install in my 2004 gp is it similar to the older style
    2004 grand prix gtp
