Thread: Running speaker wire....to the doors....help.
Results 1 to 11 of 11
  1. #1 Running speaker wire....to the doors....help.
    SE Level Member Incomudrox's Avatar
    New Holland, PA
    I have never run speaker wire to the doors. What is the best way to do this to get it though the doors? Can i just cut one end and tie the new wires on and pull it through ?? thanks.
  2. #2 Re: Running speaker wire....to the doors....help.
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    either that or take a wire coat hanger,(straightened) bend over one end- leave enough of a flat loop to put the wire in later, and secure loop w/ electrical tape. push this end through the flex peice, into the door. slip the wires through the flat loop at the end, and pull it back through. --- if needed/desired you can tape the wires to the hanger, but most times this is not needed
  3. #3 Re: Running speaker wire....to the doors....help.
    New Holland, PA
    Thanks...only reason I am doing this is because I got my headunit in the glove box. Now my right front speaker isn't working. I have ruled out the AMP,RCA's and Headunit as the problem. It's losing connection somewhere. Right now the way i have it is, I have at the harness the front speaker wires hook into the rear speaker wires and i power the front speakers using the rear speaker wires to the AMP because the AMP is in the trunk. Because they where more accessible at the time. If that makes any sense.
  4. #4 Re: Running speaker wire....to the doors....help.
    SW Chicago Suburbs
    Quote Originally Posted by Incomudrox View Post
    woah... hmmm kinda not really heh.... perhaps a diagram would help out... or are you saying youre powering the front speakers from the factory amp in the rear, by using the rear speaker wires?
  5. #5 Re: Running speaker wire....to the doors....help.
    New Holland, PA
    Quote Originally Posted by Toasty View Post
    I am powering the front speakers, using the rear wires through a after market amp. Its been working like this up until now. So it goes like this
    Headunit RCAs>AMP>AMP Power is spliced into speak speaker wire> at the harness the rear speaker wires are splices into the front speaker power wires>thus powering the front speakers.
    (I have no rear speakers)
  6. #6 Re: Running speaker wire....to the doors....help.
    Saraland Alabama
    get some new power wire, that speaker wire can't handle the current the amp will draw, you have a fire waiting to happen there
  7. #7 Re: Running speaker wire....to the doors....help.
    SW Chicago Suburbs
    Quote Originally Posted by archemedes View Post
    the POWER for the amp is going through speaker wire, or just the speaker signal?
  8. #8 Re: Running speaker wire....to the doors....help.
    New Holland, PA
    Just the speaker signal. The AMP power wire is a 2awg LOL. and a 4awg ground. I was driving and all of a sudden my right speaker started worked o well, i'm not complaining.
  9. #9 Re: Running speaker wire....to the doors....help.
    Saraland Alabama
    ok I misread, it scared me for a second
  10. #10 Re: Running speaker wire....to the doors....help.
    New Holland, PA
    Yeah I would scare me too.
  11. #11 Re: Running speaker wire....to the doors....help.
    Jan 1970
    Maquoketa, Iowa
    I ran all new wires in my car...
    The doors were tricky, I couldn't just pull them through by taping it/coathanger easy enough. I just popped the rubber boot on the door off, then popped the other side connected to the chassis. Then I threaded the wire through the door, through the boot and then through the chassis, it gave me a lot more room to work at getting it through the chassis and catching it on the other side. The rubber boot then just pops back on.
  1. What brand/style of tires are you running?
    By John02Hawk in forum Tires & Wheels
    Last Post: 02-15-2008, 01:18 AM
  2. Lambo Doors?
    By scoobyydooooooo in forum Visual/Body Modifications
    Last Post: 02-02-2008, 02:39 AM
  3. 8" Comp Woofers in Doors?
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 01-15-2008, 01:33 AM
