Thread: Radio with Theftlock--How to Activate
Results 1 to 3 of 3
  1. #1 Radio with Theftlock--How to Activate
    Sep 2017
    Winneconne, WI
    I bought a radio/CD player from a '04 GXP today. It is identical to the one in my 2008 GXP that has some display areas dim. The guy at the junkyard said it will work if I don't disconnect the battery when removing my radio. I asked about he one I took from the '04 and he said they "do it right" so it will work.
    Is this true? If not, how can I override the Theftlock when installed in my '08?
  2. #2 Re: Radio with Theftlock--How to Activate
    Oct 2011
    Toledo, OH
    There is a chip in the radio that your VIN is programmed in. It likely compares it to your BCM every time you turn the radio on. You have to take it to a dealership or someone with a Tech2 and have it unlocked. No other way besides cutting that chip out.
    7"
  3. #3 Re: Radio with Theftlock--How to Activate
    Sep 2017
    Winneconne, WI
    The '04 radio has a cassette player as well as the CD player. This would be useful to me with all my old tapes. I'll check to see what the dealer charges to enable the VIN with the radio.
    Thank you.
  1. Theftlock radio question
    By April Thompson in forum Audio, Security & Visual Electronics
    Last Post: 01-02-2015, 11:58 AM
  2. need help with theftlock in '08 GXP
    By rayl in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2011, 09:55 PM
  3. Do I need to activate Perf. Shift in stock pcm for it to be enabled?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 10-18-2008, 04:27 PM
  4. how do i reset the theftlock???
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-29-2008, 03:08 PM
