Thread: Lights on heater knob-shifter coilumn not working
Results 1 to 5 of 5
  1. #1 Lights on heater knob-shifter coilumn not working
    kentucky
    This is my first post, so if it is in the wrong place, forgive me. I have a 2007 Grand Prix and none of the lights from the radio down are working. The radio is working fine and is light up, but from there down is dark. Is there suppose to be lights in this area? Thanks for any help with this issue!
  2. #2 Re: Lights on heater knob-shifter coilumn not working
    SE Level Member MikeJenkins's Avatar
    USA
    I have a 2007 GXP and no lights on the center console are working. Any ideas on how to fix. The bulb must be a bi*&^ to get to?
  3. #3 Re: Lights on heater knob-shifter coilumn not working
    USA
    You may have a disconnect in the wiring in the back end of the center console. If your bulb is out on your shifter here is what I had to do to replace it.
    OK I fixed it on my 2007 GXP. This is what you need to do. Go to your local Pontiac Dealer parts. Tell them that you want a bulb for your shift light. They will scratch their head, look at drawings and find it. It will cost you a whole 90 cents to buy. Ask them to print you out the drawing so you can see how the little bas^&$% is installed. Now the easy part is over. In your car on the drivers side of the center column, uncrew the underside of the side of the center colum to get part of the side off. You will see a small couple of wires with a connector. That leads to your little lightbulb. Reach under the column, scratching your wrists and hands and locate the end of the wires. You will feel and maybe see a plastic knob on the underside of the shifter. Grab it if you can and twist unlock it off. There on the top side of the plastic knob is your little burnt out bulb. Replace it, test it, then put the 3 screws back in using the torx wrench. All done. Good luck as it is a beast trying to get your hands in that little place. I could not figure out how to get better access. MJ
  4. #4 Re: Lights on heater knob-shifter coilumn not working
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    ^^^I couldnt get the whole center consol out when I was running my amp hot wire. looked like u needed a special tool for the final pieces to take off ( after the easy screws ). my light is also out but dont have time to change it, good luck guys.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  5. #5 Re: Lights on heater knob-shifter coilumn not working
    Apr 2009
    Belleville, New Jersey
    I have an 06 GXP and my shifter knob bulb was out too. I couldn't figure out how to get to it either. Luckily it was under warranty and the dealer did it. I know it's not any help, but I thought I'd add my two cents...lol
  1. Fog/Driving lights not working
    By trailshredder in forum General Tech Discussion
    Last Post: 03-06-2009, 03:15 AM
  2. Blower and Auto Head Lights quit working
    By timothy_tw in forum General Tech Discussion
    Last Post: 10-30-2008, 10:34 AM
  3. PRNDL Back Lights Not Working
    By POLECAT2007 in forum General Tech Discussion
    Last Post: 10-16-2008, 09:00 PM
  4. HUD Knob
    By jcapone in forum General Tech Discussion
    Last Post: 08-15-2008, 11:30 AM
  5. Shift Knob
    By bkaab in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 03-31-2008, 02:04 AM
