Thread: Feedback/Noise in speakers on Aftermarket Systems
Results 1 to 14 of 14
  1. #1 Feedback/Noise in speakers on Aftermarket Systems
    St. Louis Mo.
    This was asked to be stickied cause it has helped a lot of people with grounding issues on their aftermarket headunits. The fix is quite simple. You take a 12ga wire and attach it to one screw at the back of the stereo and carefully wrap it around the RCA jacks at the rear of the HU. Of course you have to strip the wire and leave only a small bit at the one end of the wire. You will need two pieces of wire to complete this fix, but will make you a much happier camper with your new aftermarket car stereo.
    Here are the photos. Remember the RCA plugins to the RCA jacks will help secure the wire so they will not come out or move out of place. Now if you are having problems with with your aftermarket HU and you are not using AMPs with your new HU, you can still do this trick, but the only difference is that you will want to a ground wire from the back of the HU to a solid ground point under the dash.
    If you ever have any questions, please feel free to contact me here or via PM.
    Thanks!
    James Shafer
    St. Louis MO
  2. #2 Re: Feedback/Noise in speakers on Aftermarket Systems
    GTP Level Member dstout's Avatar
    ky
    Good Job Geddy....I think this will help people since it is a popular question.
  3. #3 Re: Feedback/Noise in speakers on Aftermarket Systems
    Feb 2009
    Virginia
    This is a good fix when ground loops are created by the RCA's between the Head Unit and connected devices(i.e. EQ's, amps, processors, etc). The difference of two grounds creates the noise.
    It also helps with blown pico fuses on Pioneers.
  4. #4 Re: Feedback/Noise in speakers on Aftermarket Systems
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    pioneer deck in mine and 3 amps 1 per front door and a sub amp , no noise here , i did a d block in the back with 4 ga about a foot long and grounded under the seat but the factory ground in the deck harness has worked fine for me . You might also want to look at the ground at the battery under the boot , usually corosion will build up under the gm terminal and you never see it like you would with a top post .
  5. #5 Re: Feedback/Noise in speakers on Aftermarket Systems
    May 2008
    Install a ground loop isolator.
    Ground Loop Isolators
  6. #6 Re: Feedback/Noise in speakers on Aftermarket Systems
    SE Level Member mriley's Avatar
    Jun 2010
    enfield ct
    nice solution to a popular problem good job
  7. #7 Re: Feedback/Noise in speakers on Aftermarket Systems
    actually its a ghetto solution to a retarded problem that shouldnt exist..........
  8. #8 Re: Feedback/Noise in speakers on Aftermarket Systems
    Feb 2009
    Virginia
    It's a solution for when treating your equipment inappropriately. i.e. plugging/unplugging RCA's while all the hardware is ON. That blows the PICO fuse. This really shouldn't exist.
    11 is louder than 10!
  9. #9 Re: Feedback/Noise in speakers on Aftermarket Systems
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Honestly, I had the same problem with my head, blew the internal pico fuse for the HU itself. This solution is a little silly honestly, there is no need to ground every single separate RCA since they are all connected to the same internal grounding point. There all connected, so ground one and you've grounded them all. Much easier and it looks better than that figure 8 crap we got goin on!
  10. #10 Re: Feedback/Noise in speakers on Aftermarket Systems
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    I think I agree.
    The shields on the RCA plugs in your head unit should be grounded inside the head unit itself. If you don't think that the ground you used hooking the unit up to the OEM harness isn't enough, then run a dedicated ground from the head unit case to the chassis...if you're really anal, run it to the battery negative terminal.
    12 gauge wire is overkill...18 gauge will do ya. I'm talking about your average 50 watt per channel head unit. If you're talking about a head throbbing amp, Ohm's law and a wiring capacity chart...both readily available on the 'net...is your friend.
    Ground loop isolators should be able to clean up minor alternator whine and some ignition popping. If it doesn't then you'll need to go to the source. Alternator whine is most likely failing or dead diodes in the alternator. Ignition pop can be traced back to the wires or the plugs.
  11. #11 Re: Feedback/Noise in speakers on Aftermarket Systems
    Never Never Land
    +1 for this ghetto solution. Took damn near all the static out
  12. #12 Re: Feedback/Noise in speakers on Aftermarket Systems
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    did the same thing to my Pioneer fized the problem
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  13. #13 Re: Feedback/Noise in speakers on Aftermarket Systems
    Sep 2013
    Boise, ID
    How common of an issue is this nowadays? What are the chances of this happening in my '00 GTP?
  14. #14 Re: Feedback/Noise in speakers on Aftermarket Systems
    Aug 2011
    Galveston
    Quick simple job man good info
    Car Clean!!!! Keep Calm and Cruise
  1. Mods I'm considering (Feedback Please)
    By bct717 in forum Visual/Body Modifications
    Last Post: 05-14-2009, 06:03 PM
  2. Aftermarket door speakers?
    By RMayer in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2009, 05:30 PM
  3. Aftermarket Door speakers
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 08-31-2008, 02:55 PM
  4. show your systems
    By Grandprixboy1224 in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2008, 11:00 PM
