Yeah but that is on the inside of the door, these are for the outside part under the door handle![]()
ohhh, I thought that was on the inside, lol.
you mean order 4 of these...?? but the blue color... vailskier
Select LED Color White WLED-WHP9-TBlue WLED-BHP9-TRed WLED-RHP9-T
WLED-xHP9-T Wedge Base Bulb
Miniature Wedge Base Bulb(194/168 type)Tower type with 9 High Power SMD LEDs
12 VDC, 360 Viewing Angle, 35 lumen - Polarized bulb
Select LED color
$ 12.95
offroadfury6,
I have never seen the lights in an 06 so I dont know if those are too long or not to be honest.
If you look at the LED in your post and then look at a stock bulb, those LEDs are much longer and may be too long to fit in your car. For example, these will not fit in my 06 Tiburon, the plastic lense cover wont go back on, lol. However, the same LED with 5 SMDs does fit.
Diode Dynamics has these and they are about exactly the same size as stock bulbs. He doesnt have the red or blue listed on his website but he is getting them this week.
If you do order from this site, just put in the comments section that you want the blue ones.
Hope this helps!!!
if i can suggest another site, it would be superbrightleds.com they have some great deals as well. if i am not allowed to post links to other sites will a mod please delete this post. Thank you.
diodedynamics.com is pretty cheap... I just gotta find out which one will fit the 04+
And when you do. I will copy. : ) haha
i actually think it is this one...
Diode Dynamics Online Catalog - LED Bulbs - 194led1w
the one you selected looks like it might be too long to fit in the housing...
Thanks Paul i will check you out. For all those 04+ model owners, try this link, should tell you what you need to know. OSRAM SYLVANIA - Replacement Guide - Start
So which lights are these ones now? I really wanna do my dash, I'm just lost with all this electronics talk. Gotta have it dumbed down more and more. hahaha
You've got 04+ so your finally someone I can have dumb it down for me. haha. If I buy these 4 bulbs as well, which bulbs are they replacing exactly?
replace the two front reading lamps and the 2 lights in the back by the windows...just interior lights...I'd love to know what kind the floorboard lights are
Well, My big thing is that I want to do my dash. Cause I want to go all blue. Going blue for those lights right now, witht the factory orange'ish lights all over the dash would clash a little. haha.
Have you done your dash Already? if so, what exact parts had you purchased? I'd be safe to order the same.
i dont think i've seen a 04+ with the dash done. although there is a write-up for the older model dashes, just soldering new LED's in place...I wouldnt mind doing my window buttons, dash and gear lights (since my gear lights have burned out anyways lol)...I wonder how u would go about changing the DIC lighting...
cant find the link under how-to section, will look alil more later
the floorboard lights should be a 194, they are in the 97-03.
As for the dash, I dont think its as easy as changing bulbs. I have seen how to's for my other car and you have to solder new SMDs onto the circuit board........
I am ordering an entire set of Blue LEDs to replace my white LEDs, lol. I will go ahead and do the 'how to' when I install those.
Not to concerned about the dash lights being orange because they wont be on when the blue lights will be.
will a 194/168 replace a 562?
