Thread: trunk wont pop
Results 1 to 4 of 4
  1. #1 trunk wont pop
    GTP Level Member 99gpse's Avatar
    Dec 2008
    Freeman, SD.
    where is the fuse for the trunk release? i installed a remote keyless/trunk opener tonight, and when testing the whole thing, running off the trunk power wire, somewhere along the line i think i blew a fuse. but when i looked, three times i pulled every fuse on the car, underhood and dash, i could not find a blow one. then i hooked the power to the module to the "power drop" plug just behind the fuse panel. and the trunk release works from the remote, but the switch wont work, and when i tested the positive wire, there was no power.. wtf?
    '90 Acura Legend LS V6 2.7 5MT ^
    '87 Acura Legend V6 2.5 5MT
    '94 Saab 900 SE V6 2.5 4AT
  2. #2 Re: trunk wont pop
    Donating Users
    Plainfield, IL
    reverse lights fuse under the hood the trunk pop in wired in with this fuse...check your reverse lights they prob dont work....
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  3. #3 Re: trunk wont pop
    Dec 2008
    Freeman, SD.
    thank you very much, it worked. and i would also like to point out, this controls the auto locks when you put the car in gear, or park.
  4. #4 Re: trunk wont pop
    Windsor ON
    I also had the same probleme, and thanks to this site I've saved myself a lot of headaches. Thanks gotboost3 you probably saved me a couple of hours in the hot sun for nothing.
  1. 08 trunk Q
    By gregy133 in forum General Tech Discussion
    Last Post: 04-02-2009, 09:08 PM
  2. ughhh, trunk wont open!
    By black98gt in forum General Tech Discussion
    Last Post: 03-12-2009, 08:23 PM
  3. What is the best way to mount a sub and amp in the trunk?
    By prettyprix in forum Audio, Security & Visual Electronics
    Last Post: 03-10-2009, 06:11 AM
  4. Ground for amp in trunk?
    By juggernaut56 in forum Audio, Security & Visual Electronics
    Last Post: 03-08-2009, 09:17 PM
  5. Trunk ?
    By b00stinGTX in forum Visual/Body Modifications
    Last Post: 02-26-2009, 02:34 AM
