Thread: noob to car audio set me straight
Results 1 to 10 of 10
  1. #1 noob to car audio set me straight
    GT Level Member 02blackgpgt's Avatar
    Jan 2009
    Kennesaw, GA
    ok 2 things:
    1)this is a really dumb question so bear with me... ive got a 10" MTX sub in a box and im going to buy an amp. my question is how do i wire up the amp? i get how to wire it for power and to the sub but where to i tap in to the audio signal? do i splice into the rear speakers, or go from the hu? details are appreciated as ive never done this before.
    2)ive got the 6 speaker delco system but my hu doesnt have the 7 band eq. was the different hu an option from the factory with/without the 7 band eq?
    if it wasnt an automatic front wheel drive four door grandmas car it would be really nice
    Mods?? What the f#ck is a mod??
  2. #2 Re: noob to car audio set me straight
    Apr 2009
    Wausau, Wisconsin
    Well there are 2 options that you have and both will work fine.
    1. You can keep the HU you have now and run a cable to the battery, ground, remote like with a aftermarket HU but then you need your aux cables. To use them with a stock HU you need to buy Scosche SLC4 Four-channel line output converter at Crutchfield.com and this will give you your RCA ports.
    2. You can upgrade your HU and run once again battery, ground, remote but instead of splicing you can run your aux cables directly into the aftermarket HU.
    It's up to you if you want to replace it or not. If you are looking into using your iPod for listening to music in your car I would go with a HU with a USB port.
  3. #3 Re: noob to car audio set me straight
    Jan 2009
    Kennesaw, GA
    ok great thanks man! i knew there was a way to use my stock hu i just didnt know what it was. and i want to do this as cheap as possible since im not really that into car audio. i was given the sub and box for free and i just want to hook it up for the hell of it.
  4. #4 Re: noob to car audio set me straight
    SE Level Member KingOfTheSouth's Avatar
    Nov 2008
    homestead
    i think thats your best best to keep your stock radio but i would go with aftermarket youll probably get a better sound out of it and you can go to any local audio shop and buy the convertor ive seen them for as cheap ass $10
  5. #5 Re: noob to car audio set me straight
    Jan 2009
    Kennesaw, GA
    alright i got it hooked up with the line out converter. but im not using the free sub/box that i had. i bought a 15" kicker already in a box and 520 watt power acoustik amp for $75 so im using that! i never cared to have a sub before but now that i do i dont think i could ever go back to stock! thanks again for all the help!
  6. #6 Re: noob to car audio set me straight
    Feb 2009
    Virginia
    Basic Car Audio Electronics
    Try to read and understand about 80% of that.
    Here's more...
    Helpful Links For Beginners - DIY Mobile Audio
  7. #7 Re: noob to car audio set me straight
    Feb 2009
    Virginia
    You're gonna get obsessed with adding more audio at some point
    Everybody gets the bug at least once
  8. #8 Re: noob to car audio set me straight
    Jan 2009
    Kennesaw, GA
    ^^oh yeah, im there. im thinking about replacing all the component speakers now but im trying as hard as i can to fight the urge. i dont want to spend any more money on appearance or audio, i want to start putting it into performance
  9. #9 Re: noob to car audio set me straight
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by I800C0LLECT View Post
    yep i'm gettin' the audio fever
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  10. #10 Re: noob to car audio set me straight
    Feb 2009
    Virginia
    Car audio doesn't have to be expensive. If you want to purchase an already engineered product by big names, then you'll be spending a lot. It's easier to actively tune and purchase raw drivers though. At least you can hear the difference as your changing settings vs. throwing it in and letting a passive cross over do all the work.
  1. Supercharger - So let me get this straight...
    By RAZOR Z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2009, 11:05 PM
  2. Aftermarket Audio + New Cars = noob
    By juggernaut56 in forum Audio, Security & Visual Electronics
    Last Post: 02-27-2009, 09:10 AM
  3. Idiotic noob looking for help with noobness about car audio
    By Autio in forum Audio, Security & Visual Electronics
    Last Post: 11-19-2008, 01:08 AM
  4. Straight Pipes on GTP?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2008, 08:12 PM
