Thread: Wiring
Results 1 to 3 of 3
  1. #1 Wiring
    Jan 2009
    here
    What's the best way to wire an amp to the battery on an 05 GT?
  2. #2 Re: Wiring
    SE Level Member kenAJUSA's Avatar
    Jan 2009
    San Diego
    Just google "wiring amp to battery", should find the information pretty easily.. only tips to really consider- 4 gauge minimum and 2/0 if you're going over 1-2k RMS watts, and MAKE SURE YOU HAVE A FUSE LESS THAN ONE FEET ON POSTIVE FROM TERMINAL! Tons of noobs always makes this mistake, and I've seen ricers that tries to do their own installs do the same. If it somehow gets lose out of your amp and touches your chassis, it can start a fire.
  3. #3 Re: Wiring
    Charles City, IA
    Run the wire under the carpet and threw the firewall. There is a grommet on the passenger floor.
    SMGPFC Two Nipple General
  1. Please help!! EGR wiring
    By Red97GPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 11:30 AM
  2. Help with LED Wiring?
    By FastKatt in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2009, 10:28 PM
  3. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
  4. gauge wiring
    By QwikGT in forum General Tech Discussion
    Last Post: 08-09-2008, 12:46 PM
  5. 04+ Wiring harness
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-27-2008, 03:22 PM
