I figured I would post up the chart, I have used for years before I pretty much memorized how much hardener to resin I need. This is for all you guys who know how to frame up a fiberglass box, but do not know how to mix up the resin.
The chart is based on temps of around 80 degrees average.
the colder the tempature is the more % of mekp you will need,
I started out always using the chart of the CC wich is easy and cheap to do; its the same as a babies medicine spoon, until I could afford the mixing cup, which is easier and most accurate.
ex:
90 degrees and higher = 1% of mekp
70 degrees to 89 = 1.25% of mekp
60 degrees to 69 = 1.50 % of mekp
59 degrees and below = 1.75% of mekp
-steven-
