Thread: MEKP CHART (Resin Hardener)=how much to use when fiberglassing
Results 1 to 4 of 4
s1795so2 MEKP CHART (Resin... 01-23-2008, 01:58 AM
archemedes Re: MEKP CHART (Resin... 01-23-2008, 08:08 AM
s1795so2 I have memorized the chart... 01-23-2008, 11:16 AM
archemedes Re: MEKP CHART (Resin... 01-23-2008, 12:01 PM
  1. #1 MEKP CHART (Resin Hardener)=how much to use when fiberglassing
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    I figured I would post up the chart, I have used for years before I pretty much memorized how much hardener to resin I need. This is for all you guys who know how to frame up a fiberglass box, but do not know how to mix up the resin.
    The chart is based on temps of around 80 degrees average.
    the colder the tempature is the more % of mekp you will need,
    I started out always using the chart of the CC wich is easy and cheap to do; its the same as a babies medicine spoon, until I could afford the mixing cup, which is easier and most accurate.
    ex:
    90 degrees and higher = 1% of mekp
    70 degrees to 89 = 1.25% of mekp
    60 degrees to 69 = 1.50 % of mekp
    59 degrees and below = 1.75% of mekp
    -steven-
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  2. #2 Re: MEKP CHART (Resin Hardener)=how much to use when fiberglassing
    GrandPrix Junkie
    Saraland Alabama
    I rarely actually measure anymore, of course I learned from doing auto body work. Good info
  3. #3
    alhambra, Il
    Quote Originally Posted by archemedes View Post
    I have memorized the chart now and rarely have to use it, but I still measure.
    I have the cup that already measures cc's.
    This is what I use, and it helps a lot
    Plastic Dispenser: TAP Plastics
  4. #4 Re: MEKP CHART (Resin Hardener)=how much to use when fiberglassing
    GrandPrix Junkie
    Saraland Alabama
    I have seen those before. I guess I do mine like a gourmet chef lol
