Thread: CEL won't come on.
Results 1 to 12 of 12
  1. #1 CEL won't come on.
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    Is the only possible fix to get a new cluster? The check engine light does not come on when you turn the key.. or start it..
  2. #2 Re: CEL won't come on.
    Medford, NY
    anybody with any thoughts? i can't find much info about this anywhere!!
  3. #3 Re: CEL won't come on.
    Feb 2008
    Try changing the light bulb behind where the display is on the dash.
  4. #4 Re: CEL won't come on.
    Medford, NY
    is it soldered in? I was able to pull a code DTC P0650 Malfunction Indicator Light (MIL) control circuit.. could that be because of a bad bulb?
  5. #5 Re: CEL won't come on.
    TDCRacing
    Guest
    Nope you just grab the plastic ''knob'' and twist. Then replace the buld. Yes that sounds like the problem for that code that was stored.
  6. #6 Re: CEL won't come on.
    Medford, NY
    thanks man, i'm totally new to these cars so I have a lot to find out.. i do like to post the solution.. that sounds like it should be it, just a dead bulb.. so i'll be back to say if that worked or not (replacing the bulb).. at least I found why my air pump wasn't working.. blown fuse! hah
  7. #7 Re: CEL won't come on.
    TDCRacing
    Guest
    Yeah I hear ya... We also like to hear the solution to the fix also. So be sure to let us know.
  8. #8 Re: CEL won't come on.
    Medford, NY
    fixed.. just a blown bulb.. onto the next thing.
  9. #9 Re: CEL won't come on.
    TDCRacing
    Guest
    Awesome.
  10. #10 Re: CEL won't come on.
    Feb 2008
    Good to hear! More problems await you down the road... J/K These are awesome cars and will last forever as long as you take care of them.
  11. #11 Re: CEL won't come on.
    Medford, NY
    yeah hopefully i dont run into too many problems.. seems like everybody that owns one loves it.
  12. #12 Re: CEL won't come on.
    Jan 2009
    hammond, IN
    Quote Originally Posted by DanGTP View Post
    very true ^^, just hit 203k miles with no problems yet
cel
