Thread: Possible ground issue or another bad GMOS-04?
Results 1 to 6 of 6
  1. #1 Possible ground issue or another bad GMOS-04?
    Apr 2009
    Belleville, New Jersey
    So, after my 4th Metra GMOS-04 I finally got everything in my 06 GXP to work. (I dont know how they can sell these things, they're such garbage.) The only problem is that I'm getting noise coming through the speakers. Its not terrible, but its enough to bother me. Since I don't have tons of experience with car audio, I was wondering what I should do. Anybody that has car audio experience that can help me out, I'd really appreciate it.
  2. #2 Re: Possible ground issue or another bad GMOS-04?
    Chicago IL
    After i have used the GMOS-04 i learned a few things about it. There is a gain adjustment on the unit, you should try turning it down to see if it continues. The other and the option i went with because i didn't like the GMOS-04 is to go with the peripheral GMAH24B.
  3. #3 Re: Possible ground issue or another bad GMOS-04?
    St. Louis Mo.
    Quote Originally Posted by FockerNJ View Post
    You mentioned noise coming from your speakers, that is going to be a grounding issue. There are a couple methods to fix that. One is to get those resistors you put on the speaker lines, and the other is the one I SWARE BY! And it costs pennies! Literally!
    If you are using an after market HU, amps connect via the RCA jacks, then you are more than likely getting a bad ground. If you are not using AMPs connected to the rear of the HU, you still are more than likely having a ground issue.
    The one way I mentioned involves purchasing those line noise resistor connectors at your local car audio shop, they run anywhere from $10-30 bucks depending on how bad the dealer wants to take you to the cleaners. And more times than not, that doesnt even include installation. But if you managed to hook up your aftermarket coupler, you could do those yourself as well.
    The other method I spoke is rather quite simple but ingenius. It is using a piece of 12-14ga wire attached to the rear plate of the radio and then wrapped around the RCA jacks, if you are using amps. The other is the same method, but instead of twisting it around the RCA jacks, you run the wire to a good ground in the car.
    That should help with the noise.
    James Shafer
    St. Louis MO
  4. #4 Re: Possible ground issue or another bad GMOS-04?
    Apr 2009
    I hooked up one of those line filters, and although its not perfect, its much better and I can live with it. Thanks
  5. #5 Re: Possible ground issue or another bad GMOS-04?
    GTP Level Member dstout's Avatar
    ky
    Quote Originally Posted by GeddyLee View Post
    You might wanna post that pic or make a sticky of the pic...it seems this question is raised alot here
    If that solution does not work for you then check your plug wires the could also be a problem.
  6. #6 Re: Possible ground issue or another bad GMOS-04?
    Apr 2009
    I now notice my bass tube is only powered on when the radio is on, so when i take the radio out to fix that ill take some pics. (I can't believe I actually paid a place to do this bad of a job...lol)
  1. Metra GMOS-04
    By FockerNJ in forum Audio, Security & Visual Electronics
    Last Post: 06-20-2009, 02:11 PM
  2. issue with ground effects
    By tod1d in forum The Rant Forum
    Last Post: 03-31-2009, 03:09 PM
  3. Factory Ground Effect
    By bct717 in forum Chevrolet Monte Carlo
    Last Post: 03-14-2009, 01:18 AM
  4. Ground for amp in trunk?
    By juggernaut56 in forum Audio, Security & Visual Electronics
    Last Post: 03-08-2009, 09:17 PM
  5. Bad Ground???
    By jjokrm in forum General Tech Discussion
    Last Post: 01-25-2009, 07:44 PM
