Thread: relay harness questions
Results 1 to 4 of 4
Slueth66 relay harness questions 02-26-2009, 08:51 PM
GeddyLee Re: relay harness questions 02-27-2009, 02:40 AM
Slueth66 Re: relay harness questions 02-27-2009, 03:47 PM
Slueth66 Re: relay harness questions 02-27-2009, 04:14 PM
  1. #1 relay harness questions
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    I installed a 9007 relay harness today and now when i have my fogs on and switch to brights it runs both the low and high beam filament. What is the reason for this i know its not good to run both at the same time so how do i fix this?
  2. #2 Re: relay harness questions
    St. Louis Mo.
    This sounds like a problem I had with my new HIDs I got. The company who made the connection to the stock lighting plug had the wires in backwards. I would have high beams on when I had the High Beam off and then would get lows when I would click on the High Beams.
    Here what I had to do to correct the problem in my setup.
    I hope that helps?
    James Shafer
    St. Louis MO
  3. #3 Re: relay harness questions
    Nov 2008
    Iowa
    Do those wires just pull out of the socket or do i have to do something else to switch them?
  4. #4 Re: relay harness questions
    Nov 2008
    Iowa
    i think i described my situation wrong. So i have my fogs on with my low beams and switch on my high beams, it runs just the high beams but when i turn my high beams off they stay on with the low beams so now i can only change between my high beams and both beams with the flick of the bright switch.
  1. p0230 fuel pump relay circuit
    By Golgo13 in forum General Tech Discussion
    Last Post: 02-27-2009, 10:31 AM
  2. underhood relay center/ voltage to fuel circuit
    Last Post: 02-06-2009, 05:10 PM
  3. Afc 2.0 ext harness
    By zexed99gt in forum PCM Tuning
    Last Post: 12-08-2008, 09:30 AM
  4. flasher relay location??
    By David99GTP in forum General Tech Discussion
    Last Post: 10-19-2008, 08:51 PM
