Thread: DIC Swap Question
Results 1 to 15 of 15
  1. #1 DIC Swap Question
    SE Level Member Tremayne0126's Avatar
    Aug 2011
    Miami, FL
    Ok so i have the normal 3 button DIC and i see alot of ppl swapping them but one question i just cant seem to answer is if i do put in the 5 button will the gas mileage gauge work?
  2. #2 Re: DIC Swap Question
    Aug 2011
    Miami, FL
    bump. need info
  3. #3 Re: DIC Swap Question
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    Gas mileage gauge?
    You mean your Odometer?
  4. #4 Re: DIC Swap Question
    Aug 2011
    Miami, FL
    no i mean the 5th button on the DIC that displays how much gas you have left on the tank
  5. #5 Re: DIC Swap Question
    St. Cloud, MN
    Yes, it will work correctly.
  6. #6 Re: DIC Swap Question
    Missouri
    If you're talking about average and instant mpgs and stuff, yes it will work. And your gas gauge will still work too. But the mileage will be off unless you get it reprogrammed at the dealer. And the dealer will say they can't >.>
    SMGPFC Member #7.5
  7. #7 Re: DIC Swap Question
    SE Level Member cannon's Avatar
    Jul 2010
    Benson, MN
    yes yes it will. But you need to get a temp sensor, and compass module if you want those to work. And depending on the year of DIC maybe tpms sensors
  8. #8 Re: DIC Swap Question
    Aug 2011
    Miami, FL
    thank you all. very wise ppl here
  9. #9 Re: DIC Swap Question
    Omaha, NE
    You shouldn't need a temp sensor. My 04 already had one installed.
  10. #10 Re: DIC Swap Question
    OKC, Oklahoma
    They got it covered, if you need one its cost like 5 bucks and to install it you need to remove the passenger headlight. It will be located behind the front clip. Also the compass module its located on the rear deck.
  11. #11 Re: DIC Swap Question
    May 2013
    Florida
    Hello, New to this forum. I have a 05 GT with the 3 button. Looking to convert to the 5 button. I see some conversions on ebay but how do you handle the milage? Dealer need to reprogram or ? Thanks I know this is a old thread.... I have been searching
  12. #12 Re: DIC Swap Question
    Omaha, NE
    Yes, a dealer or mechanic with a tech 2 device has to program the mileage on the dic to match the mileage on your bcm.
  13. #13 Re: DIC Swap Question
    Jan 2013
    Kansas
    Did the 2008 GP base come stock with the 5 button DIC? cause my buddies '08 only had 3 but my '08 has the five buttons and the radio controls on the steering wheel unlike his...
  14. #14 Re: DIC Swap Question
    Omaha, NE
    I'm sure they did a bunch of crazy stuff to the 08s to get rid of option parts they didn't want to have left over in the factories.
  15. #15 Re: DIC Swap Question
    Dec 2022
    Charlotte
    If I add a Dec of 2007 can I install tpms sensors on my Pontiac 2005 tires?
  1. Top Swap'n Question
    By BillBoost37 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2011, 08:06 AM
  2. dic swap question
    By bigdog853 in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2011, 01:33 AM
  3. Top Swap Question
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-08-2009, 06:34 PM
  4. another top swap question
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2009, 12:59 PM
  5. LOL another top swap question
    Last Post: 01-21-2009, 05:40 PM
