Thread: boost gauge doesn't light up
Results 1 to 7 of 7
tjgenest boost gauge doesn't light up 08-31-2010, 09:25 PM
matt5112 Re: boost gauge doesn't light... 08-31-2010, 09:34 PM
tjgenest Re: boost gauge doesn't light... 08-31-2010, 09:39 PM
matt5112 Re: boost gauge doesn't light... 08-31-2010, 09:41 PM
tjgenest Re: boost gauge doesn't light... 08-31-2010, 09:46 PM
matt5112 Re: boost gauge doesn't light... 08-31-2010, 09:51 PM
KeleherM Re: boost gauge doesn't light... 01-19-2022, 12:55 PM
  1. #1 boost gauge doesn't light up
    Winlsow, ME
    Hi Ive got a 2001 Pontiac Grand Prix GTP Special Edition and I cant get my boost gauge to light up. It was like that when I bought it a few months ago, the guy said maybe it was a wiring problem. But when the light hits it just right I can see that the display and buttons are all working but it just wont light up. Just wasnt sure if it was a light in there or a fuse, you know just something stupid. Just thought that maybe someone else might have had the same problem as me and could save me some troubleshooting time. Also the HUD display flickers on and off most of the time (fading out and staying off for a while), haven't had time to mess with that either and wasnt sure if maybe that was related to the problem with the boost gauge.
    NATEF Certified Auto Mechanic
    Maine State Inspection Mechanic
    Certified Amsoil Dealer
    EPA Air Conditioning Certified
  2. #2 Re: boost gauge doesn't light up
    backlight?
    dimmer switch?
  3. #3 Re: boost gauge doesn't light up
    Winlsow, ME
    the dimmer switch works cause I use it at night to dim my interior lights. Ihave had the dash apart and pulled out the boost gauge to make sure that everything was connected. the boost gauge has lighted up once since I've owned the car and it only worked for maybe 20 minutes, thats why I was thinking maybe it was some kind of a wire that was loose or broke maybe.
  4. #4 Re: boost gauge doesn't light up
    If thats the case, have fun finding it.
  5. #5 Re: boost gauge doesn't light up
    Winlsow, ME
    haha thanks I'll try using ALLDATA to see if they have a wiring diagram for the interior electrical maybe that'll help.
  6. #6 Re: boost gauge doesn't light up
    if you have access to that then you've already got a massive head start. Good luck
  7. #7 Re: boost gauge doesn't light up
    Jan 2022
    missouri
    I have recently bought a 2000 grand prix gtp. I encountered the same issue have you found out what the problem is? if so it would help a lot becuase it does not seem very many people go through the same issue online.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  3. Gas gauge works then doesn't...?
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 10-03-2008, 04:14 AM
