Thread: Whip Antenna Question
Results 1 to 2 of 2
  1. #1 Whip Antenna Question
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    This question does NOT apply to a Grand Prix (as you'll all be happy to know shortly), but the same situation may have happened to some of you, and I wanted to know if anyone had a solution.
    My son ran his girlfriend's car through an automatic car wash, and snapped the antenna base. He was able to order a replacement assembly, and we did figure out how to successfully install it. The problem is, when the original base got yanked off the car, it stripped the holes for the bolts that hold the antenna down. We tried attaching it with the double-sided tape they use for nameplates, but it doesn't hold.
    Other than replacing the fender, does anyone have any ideas to make the antenna stay?
  2. #2 Re: Whip Antenna Question
    GT Level Member mguzzo's Avatar
    Buffalo NY
    can you reach the back side to use backing nuts on the bolts that thread into the fender?
    Drill oversize and tap? or install a helicoil?
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  1. Audio (rear window) antenna wiring question 2007 GP
    By Kcintimidator in forum Introductions/Noob Questions
    Last Post: 12-09-2016, 12:57 AM
  2. Euro style antenna / stock antenna delete
    By bandits grand prix in forum Visual/Body Modifications
    Last Post: 12-21-2014, 06:03 PM
  3. Full size female antenna to mini male antenna adaper?
    By iowagtp in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2012, 02:52 PM
  4. The new whip-!!!
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 03-02-2010, 11:11 AM
  5. Stupid Question. Where is the antenna...?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-23-2008, 06:41 AM
