Thread: Inexpensive tweeters for stock location
Results 1 to 5 of 5
  1. #1 Inexpensive tweeters for stock location
    Feb 2018
    texas
    What in you guys opinions are the best inexpensive tweeters that can be put in the sail panel on the front door without too much trouble..I put in a set of Boss to go with my 5.25 Pioneers in the front, and altho they did help to pull the sound up somewhat, they are horribly bright......Would like something in the $30 to $55 range, or am I dreaming??? Can run them on the head unit ( Sony 57UP) or can amp them active, or passive....I have had many systems, but never any good tweeters, so I dont know a lot about what sounds good tweeter wise...Thanks..
  2. #2 Re: Inexpensive tweeters for stock location
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Got some great sound out of some infinity tweeters I found at the junkyard. They had active crossover and sound great paired with my 6.25" pioneers. Still have the bose amp and it sounds better than some aftermarket installs I've done with professional amps.
  3. #3 Re: Inexpensive tweeters for stock location
    St. Louis
    I just disconnected those tweets and went with a 6 1/2" door speaker when I upgraded. Don't miss them one bit with the new speakers. Everything in my GP is now aftermarket driven by a 4x100 amp and is plenty loud when I want it to be, even without a sub.
  4. #4 Re: Inexpensive tweeters for stock location
    Aug 2017
    Raytown, MO
    Quote Originally Posted by FordMan77 View Post
    Had it like this for a while too! I'm weird and like how the soundscape sounds with the tweeters up higher.
  5. #5 Re: Inexpensive tweeters for stock location
    Feb 2018
    texas
    Wow, what a lucky find in the junkyard...I think Im going to make a run to Houston when I get a chance, and audition a few sets....
  1. Why are Regals so inexpensive? (at least in my area)
    By SaukRapids in forum General Grand Prix Discussion
    Last Post: 07-28-2017, 07:31 PM
  2. Inexpensive OBD2 scanner WITH ABS and SRS
    By bradycatsmokey in forum General Tech Discussion
    Last Post: 12-14-2014, 02:27 PM
  3. Silly Stock Tweeters Question
    By thekidinbuff in forum Audio, Security & Visual Electronics
    Last Post: 12-13-2014, 05:02 PM
  4. If I put a new stereo in would I still be able to use the stock tweeters>?
    By salannelson in forum Audio, Security & Visual Electronics
    Last Post: 09-24-2009, 09:21 PM
  5. Inexpensive ways to do this?
    By BwolfGT in forum Visual/Body Modifications
    Last Post: 08-30-2009, 12:12 PM
