Thread: ZZP PCM and key fob programming
Results 1 to 13 of 13
  1. #1 ZZP PCM and key fob programming
    Donating User
    Jul 2014
    Minnesota
    I am trying to program my key fob and I've done all the steps but it still doesn't work. Would there be any sort of issue with having a ZZP PCM and trying to program fobs?
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: ZZP PCM and key fob programming
    SWPA
    PCM has nothing to do with the FOB.
  3. #3 Re: ZZP PCM and key fob programming
    Quincy, Mass
    There’s 2 different keyless modules, you have to have the right fob for the right module
    No more GP 04 Impala SS Indy:
  4. #4 Re: ZZP PCM and key fob programming
    Donating User
    Jul 2014
    Minnesota
    How do I know what fob and Module I have /need?
  5. #5 ZZP PCM and key fob programming
    Quincy, Mass
    The module is behind the dic. There’s a module A and a module B if I remember right. If you have your original key fob the part number is on the back. I’m not sure what numbers go with what module.
    Are you trying to reprogram your original fob after installing a zzp pcm?
    Make sure the battery in the fob isn’t dead, that should probably be the first thing to check.
  6. #6 Re: ZZP PCM and key fob programming
    Donating User
    Jul 2014
    Minnesota
    Well since I bought the car back in 2014 the key fob has never worked. I've replaced batteries with no luck, so I just haven't used it. I recently came across the thread on here about reprogramming the fob, so that's why I've been trying recently, Yes I just replaced the battery on Saturday.
  7. #7 Re: ZZP PCM and key fob programming
    GTP Level Member
    Jun 2016
    Cleveland ohio
    More than likely the arm that holds the battery is broken. I have soldered a few in the past and they worked until I bought some more off of ebay.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  8. #8 Re: ZZP PCM and key fob programming
    SWPA
    Agreed that is a big problem. I soldered mine when it happened to it. The other issue that happens is the buttons wear out and don't make good contact.
  9. #9 Re: ZZP PCM and key fob programming
    Sep 2015
    Cheyenne, WY
    I had received 2 fobs with my car, neither one worked.
    New battery & solder connections looked good.
    I glued pieces of tin foil to the pads & got them both working.
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  10. #10 Re: ZZP PCM and key fob programming
    Donating User
    Jul 2014
    Minnesota
    Can you still get these fobs from a dealer?
  11. #11 Re: ZZP PCM and key fob programming
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Yes but don't throw your money away like that. I've bought the ones off Amazon and they work just as well. Sure the ebay ones are good too
  12. #12 Re: ZZP PCM and key fob programming
    Donating User
    Jul 2014
    Minnesota
    Battery contacts were broken
  13. #13 Re: ZZP PCM and key fob programming
    Jan 2018
    Morgantown
    thanks!!
  1. Programming a Key Fob
    By the70judge in forum Introductions/Noob Questions
    Last Post: 09-09-2016, 11:58 AM
  2. Programming BCM
    By MyHero in forum General Tech Discussion
    Last Post: 02-02-2016, 08:16 PM
  3. Programming a fob
    By Angelo1912 in forum General Tech Discussion
    Last Post: 08-13-2012, 09:57 AM
  4. programming key fob?
    By gtp239 in forum General Tech Discussion
    Last Post: 01-31-2011, 06:24 PM
  5. PCM programming
    By tdm571 in forum General Tech Discussion
    Last Post: 12-10-2010, 09:16 AM
