Thread: Is it possible to add navigation to a 2004 grand prix that did not previously have it
Results 1 to 6 of 6
  1. #1 Is it possible to add navigation to a 2004 grand prix that did not previously have it
    Apr 2017
    IN
    I have been searching for a navigation unit for my 2004 grand prix. It has the 6cd disc changer unit with the monsoon speaker set-up. I am wondering if i purchase an OEM navigation unit could I make it work in the car, after purchasing the map disc's and updating it to current. If anyone has one for sale, or could point me in the right direction for finding one it would be greatly appreciated. Again an OEM unit.
    Thanks You
    -Gold04
  2. #2 Re: Is it possible to add navigation to a 2004 grand prix that did not previously hav
    Aug 2016
    CT/RI Border
    As far as I know, the swap is doable but has some caveats.
    I am unsure of the year cutoff but at one point you need to program the VIN of your car into the Nav as it won't work if they don't match. An updated disc will be required as well, the old maps are definitely just that, old.
    NAV units pop up on eBay all the time, any GM NAV from this generation should work.
    Sent from my ASUS_Z00TD using Tapatalk
  3. #3 Re: Is it possible to add navigation to a 2004 grand prix that did not previously hav
    Oct 2011
    Toledo, OH
    Yep, but you will have to have it unlocked at a dealership or someone with a Tech 2 device and you may not get the HUD turn-by-turn like factory optioned cars would.
    They are hard to come by, but I believe someone on here has one in the classifieds. I'm debating on setting mine as well, with antenna and map so I can go back to using ipod/subwoofer.
    7"
  4. #4 Re: Is it possible to add navigation to a 2004 grand prix that did not previously hav
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    You would need to run a wire to the PCM to get the speed sensor signal for the HUD navigation.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: Is it possible to add navigation to a 2004 grand prix that did not previously hav
    GTP Level Member simbah's Avatar
    Lala land
    you would also nee the GPS antenna. Which is located under dash by windshield.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  6. #6 Re: Is it possible to add navigation to a 2004 grand prix that did not previously hav
    SE Level Member dirtyape's Avatar
    Dec 2014
    Lomita,Ca
    Yes
    https://www.navdy.com/#see-the-road
    Thinking of getting one for my 97 gtp. My friend has one and it is pretty sweet.
  1. Replies: 23
    Last Post: 10-25-2015, 06:50 PM
  2. possible 04+ grand prix,vette navigation antenna
    By sasquatch094 in forum For Sale - Parts
    Last Post: 08-20-2013, 07:23 PM
