Thread: Replacing radio
Results 1 to 3 of 3
jimmyj Replacing radio 12-04-2016, 01:26 PM
nox Re: Replacing radio 12-05-2016, 05:18 AM
robinsone Re: Replacing radio 12-05-2016, 09:34 PM
  1. #1 Replacing radio
    Dec 2016
    Missouri
    Hello all.
    I have a 2005 Grand Prix base with the original single CD AM/FM radio. It will rarely read any CDs, half the lights are burned out, and the print has worn off most of the buttons. I was looking at just replacing it with a used functioning OEM radio. I'm not interested in an after market solution.
    I've read some other posts and if I'm understanding things correctly, even if I replace it with the same factory radio from another GP the radio would be locked until I take it to the dealer for them to reprogram?
  2. #2 Re: Replacing radio
    Aug 2016
    CT/RI Border
    I am unsure on the 2004+ radios, on the older cars theft lock wasn't automatically enabled so often you didn't need a code. The 1800 number and process for unlocking was floating around Google for quite a while should still be able to find it.
    Sent from my ASUS_Z00TD using Tapatalk
  3. #3 Re: Replacing radio
    May 2012
    Bloomington, IN
    Or just take a factory radio and swap parts. There is a post on how to swap out the lights its very easy to do. That's what I did. Find someone parting out and ask him for the radio face only, which is plastic if the buttons are in good condition. The lights can be found online. I went to bulbtown.com to find them.
  1. MONSOON radio thinks it's a BOSE radio now...
    By industrialfish in forum Audio, Security & Visual Electronics
    Last Post: 06-02-2016, 06:00 AM
  2. Replacing Oil Pan
    By Balabill in forum Engine
    Last Post: 06-18-2015, 03:47 PM
  3. Replacing LIM
    By Sudden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2013, 02:19 PM
  4. Replacing the BCM on a 08?
    By veener79 in forum General Tech Discussion
    Last Post: 03-15-2013, 07:32 PM
  5. Replacing bulbs in radio, not working
    By glassvial in forum Audio, Security & Visual Electronics
    Last Post: 01-31-2013, 01:28 PM
