Thread: remote starter issues
Results 1 to 9 of 9
  1. #1 remote starter issues
    Jan 2009
    state Pen
    what up every one like to say thanks in advance. THANK YOU
    Here's the deal I have a 06 base model GP (she is sexy as hell) the problem is like two weeks ago remote starter (factory) just said f u and it wont work. Every time you hit the key combination to activate it the alarm goes off. There is not check engine lights on, cleaned the fob changed the batts, checked the DIC its not disabled. Swung by the stealership and they wanted 125 hr to hook it up and c whats up. Does anyone have a clue i need to get this issue resolved it cold as a mutha****er outside. like i said thank any idea will be great
  2. #2 Re: remote starter issues
    SE Level Member afish70's Avatar
    Naperville, IL
    have you tried to disable it then re- enable after you drive it?
  3. #3 Re: remote starter issues
    Jan 2009
    state Pen
    yup even disconected the car bat and everything
  4. #4 Re: remote starter issues
    if you disconnected the battery you have to reprogram the remote and unit itself, what brand is it?
  5. #5 Re: remote starter issues
    May 2008
    McHenry IL
    igive u props man i helped my bud nstall a remote start on his 07
    G6 and wow it suckedtook a weekish lmao
  6. #6 Re: remote starter issues
    Jan 2009
    state Pen
    it the factory starter
  7. #7 Re: remote starter issues
    I take it your lockl and unlock still work? thrown and codes lately?
    options
    1. cycle the key multiple times, on 3 sec off 3 sec
    2. hold lock and unlock near the car for about 10 sec to re-sync remote , horn will honk and lights will flash if it works
    3. Take it to the dealer to do this.
    Transmitter Programming:
    Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
    1. Install a scan tool. Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs. Press the START soft key on the scan tool. Important: The scan tool must stay connected until all of the transmitters are programmed.
    2. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the scan tool will indicate that the transmitter is programmed.Repeat the previous step in order to program up to 4 transmitters.Remove the scan tool.
    Operate the transmitter functions in order to verify correct system operation.
  8. #8 Re: remote starter issues
    Jan 2009
    state Pen
    yea the lock and unlock still work when they want sometimes they are slow and it takes a few trys but they work.
    what do you mean by cycle the key?
  9. #9 Re: remote starter issues
    turn to forward to accessory then turn it back, continue a few times
    brandon
  1. Remote start on GP
    By Freebeer187 in forum General Tech Discussion
    Last Post: 04-12-2009, 07:30 PM
  2. 12 Volt Remote
    By mainecrab in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2008, 09:45 AM
