I have hooked up my HU, and found the two wires from the Monsoon unit that go to the center channel. I guess my question is: does the Monsoon amp process the signal and filter out things from the L/R channel and then send them to the center? Or does it take the L/R signal and then create a center from them without taking away from the front L/R channels? I need to know if I need to bypass the front L/R through the Monsoon amp, which if true means I then have to fool with the seperate tweeter signal.
