Hi. First time post. I just bought an '08 Grand Prix base and I noticed a black connector is dangling by the top of the rear window. After doing a little research, I believe this is where the antenna cable connects to the rear window. In something I read, it also made mention of a "post" on the window where the antenna connector should attach? I don't see any "post" on the window - just more or less flat window with a couple pieces of solder around it maybe. I'm wondering if something fell off. I haven't cleaned anything off yet. I did buy a Permatex rear window defogger conductive tab adhesive repair kit to try to reattach it though.
Can someone tell me how things connect up exactly? Am I missing a small component/post that should be on the window? If so, where can I order one (part number)? Or, can I clean everything up a bit and use the kit I bought to just attach the antenna piece (sort of shaped like a headphone earplug) directly to the window? Thanks for any details/info...
