Thread: Aftermarket deck, stock soeakers
Results 1 to 15 of 15
  1. #1 Aftermarket deck, stock soeakers
    GT Level Member Hpiracr28's Avatar
    Apr 2016
    Elmira, NY
    So I have my grandmothers grand prix now, just waiting on some paperwork from the estate to get all the info changed over. But anyway, the stock speakers sound good for what I'd use them for...Good lows, no crackling on increased volume. Just the stock deck is out of date. I'm taking the deck out of my camry since it has usb, cd, aux, bluetooth. Will I lose the factory sound, or will it sound better? I've always upgraded both speakers and head unit, not just one, so I'm not sure. I don't want to take the aftermarket pioneer premier speakers out of my camry because they are more for highs as I planned on putting in a subwoofer but never got to it.
  2. #2 Re: Aftermarket deck, stock soeakers
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    You will need either an adapter harness, or lose the onstar/door chime. 04+ or 97-03?
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: Aftermarket deck, stock soeakers
    Apr 2016
    Elmira, NY
    It's a 2003
  4. #4 Re: Aftermarket deck, stock soeakers
    Oct 2014
    Frederick, MD
    Ok, there's a thread around here somewhere on aftermarket harnesses, but if you do decide to cut and splice, I have the wiring diagrams for 97-08... You'll need to run a 12v switched wire from either the passenger side or the underhood fuse block in order to get it to function properly and turn on with the key
  5. #5 Re: Aftermarket deck, stock soeakers
    Apr 2016
    Elmira, NY
    I've dealt with splicing on a lot of my stereos. I decided one time to do a harness...much easier. Any help or info you could share would be great. Any recommendations on which wiring harness?
  6. #6 Re: Aftermarket deck, stock soeakers
    Oct 2014
    Frederick, MD
    Crutchfield will have exactly what you are looking for. even down to the type of stereo you have.
  7. #7 Re: Aftermarket deck, stock soeakers
    Apr 2016
    Elmira, NY
    Metra 70-1858. Do I still need to run the 12v switch with this wiring harness as you suggested?
  8. #8 Re: Aftermarket deck, stock soeakers
    GXP Level Member
    Mar 2015
    Tomball
    No that's only 04+
  9. #9 Re: Aftermarket deck, stock soeakers
    Oct 2014
    Frederick, MD
    No. The 12v switched power is only needed if there is no adapter, or if the previous owner decided to try to splice it on his own and hooked up two of the speakers to the wrong sides, one speaker to amp signal and power antenna, and the other to the illumination on signal (it was fun trying to figure that shizzz out)
    The adapter should allow the head unit to work as if it was stock.
  10. #10 Re: Aftermarket deck, stock soeakers
    Apr 2016
    Elmira, NY
    OK awesome. Soon I'm going to get the dash kit and the wiring harness. Thanks for the assistance.
  11. #11 Re: Aftermarket deck, stock soeakers
    Oct 2014
    Frederick, MD
    That harness is 5 bucks on Amazon. good luck with the install
  12. #12 Re: Aftermarket deck, stock soeakers
    The adapter is not going to look anything like that picture.
    It will look like this.
    Is it safe to assume that you do not have BOSE?
  13. #13 Re: Aftermarket deck, stock soeakers
    Oct 2014
    Frederick, MD
    That's the one on crutchfield
    Amazon for half the price.
    They look the same, aside from the color of the plug.
  14. #14 Re: Aftermarket deck, stock soeakers
    Jul 2010
    Coquitlam,BC,Canada
    My install with basic non Monsoon/Bose stereo..... http://chrisb.users.superford.org/Gr...eo/Stereo.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: Aftermarket deck, stock soeakers
    Apr 2016
    Elmira, NY
    Quote Originally Posted by Slick2500 View Post
    Correct, I do not have the BOSE stereo.
  1. Aftermarket deck with GMOS 100, NO SWC
    By mckillin in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2013, 07:09 PM
  2. DIC Funtions after Installing Aftermarket Deck
    By extreme in forum Audio, Security & Visual Electronics
    Last Post: 09-08-2012, 04:05 PM
  3. stock deck vs aftermarket replacement advice
    By NAC in forum Audio, Security & Visual Electronics
    Last Post: 08-24-2012, 07:59 PM
  4. Installing a aftermarket deck on a Bose system.
    By Pontiacman76 in forum Audio, Security & Visual Electronics
    Last Post: 09-07-2011, 09:19 AM
  5. aftermarket deck
    By whitegtp in forum Audio, Security & Visual Electronics
    Last Post: 07-21-2009, 09:20 PM
