MrDavid, any recommendations for a fuse to put it on in the interior fuse panel?
What are you wiring up?
Just an aux port
The sunroof fuse is fine, if you are concerned about the amperage draw, get a relay and run a power wire with an inline fuse to the battery for auxiliary power and just use the sunroof fuse as a switch to turn the relay on.
I tried searching, but other than just text can anyone find an actual picture (drawing pic) or the pin out and plug style?
This is the info I have so far:
2006 Pontiac Grand Prix Factory Stereo Install Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Run a wire from the back of the radio to the steering column or fuse box for a switched power source.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Violet
Car Stereo Amp Trigger Wire: Violet
Car Stereo Amplifier Location: Located under the center of the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
I'm looking for this, for our cars:
http://ww2.justanswer.com/uploads/GU...8_102526_B.gif
Best of luck on the hunt. I still haven't found it. If you do find one please post it.
