Thread: Climate Control Lights - 2004 Grand Prix GT2 with heated seats
Results 1 to 7 of 7
  1. #1 Climate Control Lights - 2004 Grand Prix GT2 with heated seats
    SE Level Member Michigan04GrandPrix's Avatar
    Jan 2009
    Macomb, Michigan
    I have a 2004 Pontiac Grand Prix GT2 with heated seats. Inside the climate control (CC) I have a couple of lights that burnt out and I want to replace them. I already took the CC out and opened the unit to make sure I had access to the lights. They are soldered in but not a problem. I just need to know if anyone knows the voltage (12v or 14v) and size of bulb (3mm, 4mm, 4.7mm) to put in there. I am not talking about the led bulbs but regular two prong incandescent bulbs.
    2004 Grand Prix GT2
    Joe From Michigan (It's cold up here!!)
  2. #2 Re: Climate Control Lights - 2004 Grand Prix GT2 with heated seats
    Dec 2008
    midwest
    same issues, some lights burned out in climate control,
    if you ever find a answer to this please let me know, thanks
  3. #3 Re: Climate Control Lights - 2004 Grand Prix GT2 with heated seats
    SE Level Member stealth06's Avatar
    Dec 2012
    New York
    I replaced several of those bulbs on my 06. I just brought the panel with the old bulbs to Radio Shack and matched them up to what they had there. I used 12 volt bulbs and they have been fine for over a year now. Good luck.
  4. #4 Re: Climate Control Lights - 2004 Grand Prix GT2 with heated seats
    Jan 2009
    Macomb, Michigan
    ALL DONE
    To be on the safe side I ordered all three 14v bulbs. 3mm, 4mm, and 4.7mm bulbs online from Ebay. 4mm was the correct ones and they were the exact size and brightness as the original. Installation was a breeze. Took the radio cover off, then unscrewed the 4 screws holding the climate control and storage bin (under the climate control). Carefully unplugged the wiring harness from the back of the climate control so I could work on the unit in the house. Removed the screws from the back of the climate control unit. Remove the knobs from the front of the climate control. Then pulled the unit apart into two pieces. Took unit back into car and plugged wiring harness in to see which lights were burnt out. Turned on lights and found I had three bulbs burned out. Turned off lights & car. Unplugged wiring harness and took unit back into house. Used thin wire cutters to cut off the burnt bulbs from the circuit board leaving just the stubs of the bulbs sticking out (so I had something to solder the new bulbs leads to). Then I heated up the soldering gun and worked some magic to get the new bulbs to be soldered and solid and in the correct position. Before I put the unit back together I once again took it back into the car, plugged in the wiring harness, turned on the lights, and verified that the new lights were working. All were so started the process of putting everything back together. Shut off car, unplugged wiring harness, took it into basement. Put front cover back on and secured it with the screws. Pushed the 3 knobs back on. Then took unit back out to the car for re-installation. Plugged the wiring harness back in, pushed the climate control and storage bin back into the hole in my dash, screwed them in, snapped back on the dash trim piece, and then turned on the car one last time to check the work. All lights now working! Took 30 minutes total with most of it being the soldering and running in & out to test the unit. Good Luck!
    PS - Do not use 12v bulbs. The 3mm bulbs are smaller than original and will be dimmer, and the 4.7mm are bigger and will be brighter than original.
    2004 Grand Prix GT2
  5. #5 Re: Climate Control Lights - 2004 Grand Prix GT2 with heated seats
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by Michigan04GrandPrix View Post
    ALL DONE
    Is there a bulb number that you used? We have an electronics house locally that may stock that bulb. I've got to do the same job to my control head.
  6. #6 Re: Climate Control Lights - 2004 Grand Prix GT2 with heated seats
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    How did you get the control head apart? I took mine apart, but cannot seem to get the board off of the front so I can get to the light bulbs. I could probably keep prying, but I don't want to break it.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  7. #7 Re: Climate Control Lights - 2004 Grand Prix GT2 with heated seats
    Jan 2016
    Michigan
    I'd like to attempt is process for a couple of newly burnt out bulbs on my 2007 Grand Prix. Does anyone have a link to the bulbs on eBay or Amazon or something? Thanks for any help!
  1. where to find a climate control panel 04 gp gt heated seats
    By trucker1211 in forum Wanted To Buy - Parts
    Last Post: 07-24-2013, 08:38 AM
  2. Climate control/heated seat lights '07 GP
    By conservasteve in forum General Tech Discussion
    Last Post: 01-19-2013, 11:15 PM
  3. 03 grand prix se climate control issue
    By gallupdm in forum General Tech Discussion
    Last Post: 08-15-2012, 01:40 PM
  4. 1998 Grand Prix Heated Seats Wont Turn Off
    By njfelix0712 in forum General Tech Discussion
    Last Post: 02-19-2011, 09:35 PM
