I still would love a HUmount for the later model. Maybe ill have to just make something.
Sent from my ASUS_Z00TD using Tapatalk
Regarding the stereo, I'm unable to set the fader to rear bias, as is my preference. Is that on purpose? The setting is there but nothing happens. Manual says something about "if available" which makes no sense to me.
Which stereo did you get and did you get the full adapter harness? When I did my '99 fader worked fine.
Does it allow you to change fader at all? If so, fade all the one one direction, and balance all the way one direction, see what happens. Change balance to opposite setting, see what happens.
As far as adapter harness, crutchfield should sell the steering adapter kit and the wiring adapter kit. It should be plug and play, the adapter to radio and adapter to factory wiring.
You will have to typically splice the in between on the radio end, but directly plug into the car. As far as I know the fader should be 100% controlled by the radio itself. I'd advise checking crutchfield's site or some audiophile sites regarding the actual stereo.
A cursory search of pioneer radios is that a ground fault can cause some features to fail. Try reinstalling your radio and pulling negative battery terminal for 1 minute.
Edit:
Check your owners manual, there is a post install initialization setup on pioneers, some ship from the factory with the wrong output mode enabled which will cause your issue.
@nox, thank you very much! I did the reset you mentioned, it was in the manual, but I never saw it. Probably too excited to get it installed. Everything works perfectly now, I really appreciate your help!
Its all good, now all you need is to get those new speakers to bump.
The hard part on the fronts is the door panels. I'd advise getting extra pins as they break ridiculously easily when pulling the panel. With tweeters the hard part will be feeding the wires through the door, string and a weight of some kind will be your friend.
As for the rears, be careful with the pull tabs on the bottom of the bench seat as they like to break off. When replacing the rear shelf be extremely careful as it like to fold under the shroud for the breaklight instead of into the groove.
The only potential issue is the dome on the tweeters. Not sure the clearance on them.
With the LEDs in the interior, the radios dimmed at night looks washed out. Can I just cut the illumination wire to the stereo? Not sure which wire it is, but I've done it on other cars.
