Thread: Aftermarket amp on a oem stereo
Results 1 to 10 of 10
  1. #1 Aftermarket amp on a oem stereo
    Oct 2015
    Qulin Missouri
    I was wondering how hard would it be to put a aftermarket amp on a oem stereo on a 06 gp without factory amp. I checked around and i cannot find any threads on this. I was also wanting to keep from cutting wires also.Do they make a harness for the speakers to keep from cutting wires? Thanks for any help on this.
  2. #2 Re: Aftermarket amp on a oem stereo
    SWPA
    You need a line converter to do so.
  3. #3 Re: Aftermarket amp on a oem stereo
    SE Level Member vredesbyrd's Avatar
    Aug 2014
    SK Canada
    Some amps have line level inputs. I would get a deck first. Adding a deck only ups sound quality way more than a sub. If you just want thumping bass ignore me
    Sent from my GT-I9505G using Tapatalk
    02 GT. Transgo shift kit, stereo
  4. #4 Re: Aftermarket amp on a oem stereo
    SWPA
    I dont know about 02s but the factory stereo in my 07 ain't that bad and a simple added amp and sub would make it sound pretty darn good.
  5. #5 Re: Aftermarket amp on a oem stereo
    Aug 2014
    SK Canada
    Maybe the newer stereos are better. I am comparing an aftermarket deck to the stock stereo in my 02. Personally I would go for components and a deck before a sub but it all depends what your goals are
  6. #6 Re: Aftermarket amp on a oem stereo
    i popped in all new speakers a amp and sub with a single 12 inch and its a load better then it was.
    vid to do the radio's speakers.
  7. #7 Re: Aftermarket amp on a oem stereo
    SE Level Member thekidinbuff's Avatar
    May 2013
    Buffalo, NY
    Quote Originally Posted by Grand prix 06 View Post
    I did exactly what you want to do.. only downfall is i think it would sound better with an aftermarket radio. Go to your nearest junk yard, find/pull out the radio, unplug the plug and cut the plug from the harness. This way you dont have to cut your stock harness. You can pop the wires out of that plug/original harness in the car and insert them into your new plug. You will need a line converter if the amp you get doesnt have line level inputs, i used a 4 line (4 speakers) and that converts it to RCAs that run to the amp. I actually ran new 14ga speaker wire to each speaker to from the amp. 400W Amp, 100 Watts RMS per speaker. Yes im deaf now. Dont know what way your going exactly so just ask
    2002 Pontiac Grand Prix GTP
    2006 Pontiac GTO LS2 M6
  8. #8 Re: Aftermarket amp on a oem stereo
    GXP Level Member
    Mar 2015
    Tomball
    Unless your talking about a factory radio from the 80's you won't be able to tell the difference in sound quality if it's installed properly. Especially with the amplifiers made these days with 5-6 times the distortion, no headroom and just about 0 damping factor.
    Jeff
  9. #9 Re: Aftermarket amp on a oem stereo
    Jun 2015
    Clearwater, FL
    Quote Originally Posted by J57ltr View Post
    Jeff
    I can somewhat agree with this.. I just replaced the factory bose setup with all Rockford fosgate speakers on a pioneer 4-channel amp and aftermarket deck. The sound clarity and loudness has increased much, but the woofers aren't putting out nearly as much sound themselves as compared to the bose setup.
  10. #10 Re: Aftermarket amp on a oem stereo
    GXP Level Member
    Mar 2015
    Tomball
    Then you did something wrong. I hope you removed all of the Bose equipment as they typically have an amp at each speaker. Bose is a totally different animal. They use crappy speakers in properly designed enclosures with matching crossovers to get the great sound they do. But if you are saying that you removed everything and you only have your stuff in there now the. It's your installation that is the issue. Subs can be wired out of phase (common), the enclosure can either be too large or small for the driver, the crossover could be adjusted improperly, there is a lot. Then you have to look at the amp what are the specs on the amp itself. I have seen amps these days that have THD in the over 1% range with dampening factors of less than 100 and signal to noise ratios in the 80's and channel separation comparable to a mono amp driving 2 seperated speakers, if you catch my drift.
    Jeff
  1. Aftermarket stereo in a 06 gp
    By Grand prix 06 in forum Audio, Security & Visual Electronics
    Last Post: 10-21-2015, 12:30 PM
  2. Help with aftermarket stereo
    By Cody15 in forum General Grand Prix Discussion
    Last Post: 11-14-2014, 03:28 PM
  3. Aftermarket stereo
    By Mikee in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2014, 06:36 AM
  4. Aftermarket Stereo SWC
    By MattF in forum Audio, Security & Visual Electronics
    Last Post: 02-23-2013, 06:29 PM
  5. Aftermarket Stereo
    By gravens86 in forum Introductions/Noob Questions
    Last Post: 01-04-2013, 02:49 AM
