Thread: Tips
Results 1 to 20 of 25
  1. #1 Tips
    SE Level Member 08gxpghost's Avatar
    Jul 2015
    Iowa
    Ok so I am ordering parts for my ls4 gxp tmr! I'm getting everything I list from overkill! The intake kit, the shift kit, and also the tune from overkill! And a transmission cooler from a different site! What I'm asking is how did you guys send your pcm and tcm to overkill? What did you use? Are they trusted?
    Sent from my SM-G900V using Tapatalk
  2. #2 Re: Tips
    SE Level Member Peirce1970's Avatar
    Myrtle beach, S.C.
    I never sent back my old one. I decided to keep it just in case I ever wanted to switch back to stock.
  3. #3 Re: Tips
    May 2015
    United States
    I purchased mine from Will at overkill. Made a huge difference. I also kept the old ones since it's my daily driver. Acceleration and shifting definitely improved.
    Sent from my SM-G920V using Tapatalk
  4. #4 Re: Tips
    Jul 2015
    Iowa
    Quote Originally Posted by 2006whitegxp View Post
    So you guys paid the extra 300 to kep your stock one and rented the scan tool
  5. #5 Re: Tips
    May 2015
    United States
    Took mine to local shop. Charged me 25.00 to re-program. Took 5 minutes only. I think the core was 150-175 at the time.
  6. #6 Re: Tips
    Jul 2015
    Iowa
    Oh yeah there's not a local shop in iowa that's close to me
  7. #7 Re: Tips
    May 2015
    United States
    If I remember correctly advance or auto zone can do it. I drove mine for 2 weeks before having it done. Was only to re-learn crank position. Ran fine only check engine light.
  8. #8 Re: Tips
    Jul 2015
    Iowa
    Oh okay so it doesn't effect the engine or car at all? So your saying I should go the route where I have 2! The stock and the tuned? So oreileys or auto zone can fix the engine light?
  9. #9 Re: Tips
    May 2015
    United States
    They can in Florida I know. I am building my engine now and going to put the old ones back in so I can have it tuned on dyno. The problem with overkill is once he programs it he is the only one who can modify it. They are in Canada so can be a pain. I am going to sell mine cheap since I won't be able to use them with the new engine if your interested.
  10. #10 Re: Tips
    Jul 2015
    Iowa
    Will it work with my car? Doesn't the Vin matter
  11. #11 Re: Tips
    May 2015
    United States
    Not sure but I thought he only needed vin to unlock it. Could email him at willoverkill@gmail.com. Responds fairly quickly.
  12. #12 Re: Tips
    Jul 2015
    Iowa
    How muxh u want for them
  13. #13 Re: Tips
    May 2015
    United States
    Looks like he is charging 175 plus shipping. I would sell them for 75 plus whatever shipping is. Saves 100
  14. #14 Re: Tips
    Jul 2015
    Iowa
    Okay and that's just his regular tune for a gxp?
  15. #15 Re: Tips
    May 2015
    United States
    Yes. Premium fuel and turns ac off above half throttle.
  16. #16 Re: Tips
    Jul 2015
    Iowa
    That's weird lol
  17. #17 Re: Tips
    May 2015
    United States
    He said it gives a little more power by eliminating the extra drag.
  18. #18 Re: Tips
    May 2015
    United States
    Changes shift points for alot more firm shifts also.
  19. #19 Re: Tips
    Jul 2015
    Iowa
    I emailed him and he replied within minutes he said your tune is specific to your vehicle
  20. #20 Re: Tips
    May 2015
    United States
    That sucks. This is what mine had done.
    Features/Benefits:
    Gains of 10-20 wheel horsepower anticipated on mild intake/exhaust setups
    Tuning available for 87, 89 mid grade and 91/93 premium gas available
    Stronger mid-range torque off the line and stronger 2nd gear acceleration
    Torque management smartly revised to eliminate power limitation
    YOU'LL LOVE AN OVERKILLED TRANSMISSION! Completely revised shift behaviour at part throttle, less bogging, 6000rpm 2-3 upshifts
    Overkill exclusive Transmission fluid pressure management reduces fluid temperatures, reduces shuddering and slip/bump, improves life expectancy!
    Displacement On Demand in 4th gear highway only, can be disabled on request for oil burning or exhaust sound issues
    Improved MPG possible, more consistent MPG tank to tank
    Revised cooling fan operation for stock thermostat, fans stay on at Key off for 1 minute as required (Reflash/HPTuner only)
    Speed limiter removal
    A/C Compressor shutoff at heavy throttle to recapture lost horsepower (Reflash/HPTuner only)
    Reduced Traction Control intervention
    P0420 removed for high flow cat converters
  1. i want new tips!
    By QwikGT in forum Visual/Body Modifications
    Last Post: 04-18-2012, 01:19 AM
  2. Dual tips or trapezoid tips?
    By GTLGDP in forum Visual/Body Modifications
    Last Post: 01-19-2012, 11:42 PM
  3. Tips please.
    By Koniig in forum Visual/Body Modifications
    Last Post: 09-12-2010, 12:52 AM
  4. looking for tips
    By dkski123 in forum Shops and Community Heroes
    Last Post: 05-03-2010, 08:57 AM
