Thread: Catalytic Converter Code
Results 1 to 14 of 14
  1. #1 Catalytic Converter Code
    Oct 2012
    Iowa
    I recently had an issue which was stated my catalytic converter was failing, long story short it turned out to be a complete transmission rebuild...anyways the cat was changed out and ever since I have had a PO420 code and only this code. The shop changed the cat out to another new one and still have the same code. Is there something else I should be checking?
  2. #2 Re: Catalytic Converter Code
    what year car you got there?
    its the rear o2 setting the code most likely due to a hi flow cat. a emulator will move the o2 out the pipe some and help to get rid if it. or you can find some one with a tune to tune the code out.
  3. #3 Re: Catalytic Converter Code
    Oct 2012
    Iowa
    Its an 07
  4. #4 Re: Catalytic Converter Code
    01 up are very picky about the cat and the rear o2 sensor. cheap way is to get a simulator and try that out.
    heres a vid, this will explain it better.
  5. #5 Re: Catalytic Converter Code
    Oct 2012
    Iowa
    Is this something the shop should be responsible for then?
  6. #6 Re: Catalytic Converter Code
    not really unless they installed a oem cat. but those cost much more then after market cats. its 5 bucks and and 1/2 hour of your time. its worth a shot.
  7. #7 Re: Catalytic Converter Code
    Oct 2012
    Iowa
    Alright thanks I'll check it out
  8. #8 Re: Catalytic Converter Code
    Oct 2012
    Iowa
    Ok, so I do not have the ability to use a drill press or lathe. Would simply swapping the rear O2 sensor for a new one be a good idea in this case? Bare in mind I am not having any other code, it is JUST P0420.
  9. #9 Re: Catalytic Converter Code
    what lathe or drill press? yo uneed a drill and a bit, that s it. you can hold the emulater with vice grips or some thing.
  10. #10 Re: Catalytic Converter Code
    Oct 2012
    Iowa
    Quote Originally Posted by ScottyDoggs View Post
    Just referring to the video that was linked.
  11. #11 Re: Catalytic Converter Code
    thats stuff not needed, i dint watch that whole vid before posting it.
    vice grips and a drill works, or a vice and a drill. drill the bottom of the emulator out.
  12. #12 Re: Catalytic Converter Code
    Arizona
    just get a tune and have it shut off
  13. #13 Re: Catalytic Converter Code
    Quote Originally Posted by 91parkave View Post
    This. Much easier.
  14. #14 Re: Catalytic Converter Code
    Enfield, CT
    Not really an emulator scott but whatever lol
  1. WTB: Catalytic Converter
    By 91RS in forum Wanted To Buy - Parts
    Last Post: 06-16-2014, 12:20 PM
  2. catalytic converter
    By musicman126 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2013, 12:09 PM
  3. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  4. catalytic converter
    By mmerrittjr in forum Introductions/Noob Questions
    Last Post: 02-16-2011, 11:49 PM
  5. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
