I picked up a 07 gxp with a bad engine. If I came across a 05-06 for cheap can I swap? Or what needs to b changed?
Sent from my XT1254 using Tapatalk
you would need a 58x to 24xconversion moulde from linglenfelter for the crank sensor and same deal with the cam pick up sensor. unless you physically swap cam gear and crank shaft. otherwise its striaght forward
How much would they run? Would it b worth doing? Or just find a newer engine.
Well I got 2. Both with spun rods. Damn kids. Lol
I mean **** why not just replace the bearing and call it a day, update the oil pan gasket while youre in there
Possaibly could do that.. I was just wondering about the swap. The bone yard I go to. Did have a smashed gxp there. Hard front hit. Not sure if its still there yet. Also I could get it cheap.
Not sure its been awhile since I seen it.
Too much work to make an 05-06 work. Ideally you'd need to do what I did in my 06 Trailblazer and my LS3 engine which is remove the crank, have the engine shop press off the old crank reluctor wheel, buy the alignment tool from I forget where for $100, press on the 07+ reluctor wheel, and reinstall the crank. Then you need to swap the cam gear to the 4x pickup. If you have two engines, just have the one engine rebuilt, is my advice
Well I'd take the extra engine you got for cheap, ha.
Definitely stay away from the Lingenfelter conversion box. Those things are junk...ask me how I know...
LOL, I found one for 650. With 129,000 on it. Thinking of grabing that. Then maybe get one of the junk ones built.
