Thread: GXP Exhaust
Results 21 to 40 of 45
  1. #21 Re: GXP Exhaust
    SE Level Member Beamie's Avatar
    Aug 2008
    Philadelphia, PA
    I'll probably do some more tuning in a week. I'm real busy with the business.
    '86 Pontiac Trans Am: Blueprinted 500+ HP Small Block (Power Train and Chassis being prep for Track)
    '06 Pontiac Grand Prix GXP: K&N CAI; Jet MAF; AiRaid TBS; MagnaFlow Exhaust; Tint: 20% Front, 15% Rear (This Is ONLY The Beginning)
  2. #22 Re: GXP Exhaust
    Ohio
    I have a 3" Magnaflow on my GXP. Its a head turner for sure
  3. #23 Re: GXP Exhaust
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    Very nice tips
  4. #24 Re: GXP Exhaust
    Wichita, KS
    Quote Originally Posted by Beamie View Post
    Just thinking and knowing the principle theory about it, you definitely will through a code. I'm trying to learn more about the HP Tuners program and when I get better at it I'll probably be doing a lot more mods. I'm ol' skool. Give me time to catch up. we ol' men are like fine wine. We might not be as quick as we used to be, but we're still fast enough to kick your A _ _! Well, you know what I mean.
    Beamie,
    I've got the code issue. I'm running a magnaflow exhaust which sounds beautiful. My exhaust is not throwing the code. However, my GXP has an electronic cut out which allows it to bypass the mufflers and go straight exhaust from the cat. every time I open this it throws the check engine light.... Do you have any suggestions on how to correct this code or are you aware of a tuner system that will correct this? My computer throws the code b/c of too much air flow then the exhaust is wide open. Thanks for your help.
    http://s75.photobucket.com/albums/i288/ucquality/?action=view¤t=MOV02869.flv
    Last edited by jvansickle; 09-24-2009 at 03:17 PM. Reason: adding link to exhaust cut out
  5. #25 Re: GXP Exhaust
    montreal quebec canada
    cause i hve the same vehicle as cable guy and want to add hp
  6. #26 Re: GXP Exhaust
    Oxymoron: Civic - Fun IR II IP IDEATH's Avatar
    South
    i got flowmaster single chamber,res delete and knn cai, man it just dont look like that car should make that kinda sound lol i love it. only set me back maybe 600 for everything
    "Last night I didn't get much sleep so in the morning I made my coffee with red bull instead of water, I got half way to work before I realized I forgot my car."
  7. #27 Re: GXP Exhaust
    Nov 2009
    SoCal
    is the magnaflow kit worth it? or should i just get some mufflers and remove the resonator. BTW I have an 08 GXP
  8. #28 Re: GXP Exhaust
    Norristown, PA
    dont remove the resonator unless you want rasp...get some new mufflers if you want a deeper sound
  9. #29 Re: GXP Exhaust
    ^^GXP dude...he's got a V8
  10. #30 Re: GXP Exhaust
    Jan 2009
    Farmington Hills, MI
    Quote Originally Posted by GXPFiend View Post
    A lot of people like the magnaflow sound with the matched resonator, and instead of 2.5" to the Y and then 2" to the muffler you get 2.5" the whole way. Plus it bolts on easy and looks really clean, and you get measurable HP gains. As far as bolt on mods go, I've never heard anyone complain after they bought one.
    That said, I saw an article by a Dynomax engineer that claimed there is only 2-4 HP to be found in the piping if you keep the same size or make a small increase. Now if you were making a lot more HP than stock, or had a power adder, then the exhaust pipe size will become a restriction and rob more power, but for a mostly stock car there isn't much power there.
    You DO take a big hit in the cat and the mufflers. You can buy most aftermarket mufflers for about $70 each in a 2.25" size, and a Hogan downpipe with a high-flow cat is $300. Throw in a trip to your exhaust shop to get the mufflers welded on, res delete, and maybe some tips, and I think you get more bang for your buck. But since there are so few bolt-ons for this engine and every HP counts, I think the Magnaflow kit will max out your performance even if it costs more.
    Personally, I'm eyeballing a set of Hooker Maxflows (quiet at idle and cruise, really loud at WOT, nice power gains) if they fit (I haven't measured yet), but Magnaflows are my second choice. I like glasspacks over chambered mufflers, but a lot of guys love that flowmaster sound too.
    BTW, I heard there are ways to get the kit cheaper than $698 just by shopping around and asking. The cheapest I've read is $516 shipped, but I don't have any personal experience.
    2007 GXP, CAI Intake, 85mm MAF, LS6 Intake Manifold, 42# LS3 Injectors, PRC Ported and Milled 243 Heads - 11:1, 224/232-113+5 Comp Cam, PAC 1218 Springs, DT Headers (w/Custom Crossover Pipe), Cutout and Maxflows, TEP Transmission (3.29s), HP Tuned by Me, Pioneer Speakers and MTX Subs, 13.1 @ 108.7 on street tires at full weight.
  11. #31 Re: GXP Exhaust
    Nov 2009
    SoCal
    I don't want a raspy or racketty sound. I want a deep throaty sound but definately a head turning sound. I'm thinking about just throwing on some MagnaFlows and maybe a DP later on down the road. I was thinking about going to the same place that I got my truck but they charge $100/muffler and $40 to install each muffler for a total of $280.00
  12. #32 Re: GXP Exhaust
    $280 for mufflers and install?
    Your getting bent over
  13. #33 Re: GXP Exhaust
    Nov 2009
    SoCal
    well that's where i'm stuck. should i just save the money for the Magna Flow cat-back kit?
  14. #34 Re: GXP Exhaust
    I'd get a catless 3" DP and have someone that does good work custom make a catback..its cheaper
  15. #35 Re: GXP Exhaust
    South
    wow, I didnt pay but $250 for 2 flowmasters, res delete and new tips all installed. may not the cheapest but it was where im at.
  16. #36 Re: GXP Exhaust
    Nov 2009
    SoCal
    how do you like your flow masters?
  17. #37 Re: GXP Exhaust
    South
    they are beast if you get the single chambers, I had the dual chamber first but they didnt quite put out the noise I wanted...I mean they sounded good just not loud enough. just look at my videos on youtube to see what singles sound like for the newer vids, the older ones like the accel. and the dyno are the dual chamber.---------oops just went and checked, youve already commented on a couple of vids
  18. #38 Re: GXP Exhaust
    Aug 2008
    Philadelphia, PA
    If you don't mind me asking. What is the intended purpose of you modifying your vehicle. Race, Street, or Bragging rights?
    My primary goal is to have a true 12 second car. I don't want to go faster than that. I drive me car on the highway and have to be realistic about it.
    To keep a little low end torque you need a little back pressure to maintain drivability.
    Talk to engine builders and pro racers to get a better insight on this whole exhaust thing. Let not get too crazy for the street.
  19. #39 Re: GXP Exhaust
    Lol at super 40's being too loud... Super 44's or bust!
  20. #40 Re: GXP Exhaust
    South
    i didnt say they were too loud, what are super 44's? possibly the next level for me?
  1. New SLP exhaust set up
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-10-2008, 04:44 PM
  2. exhaust
    Last Post: 11-12-2008, 02:25 AM
  3. exhaust
    By Keet04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2008, 08:37 AM
  4. exhaust Q
    Last Post: 06-19-2008, 10:26 PM
