Thread: Trouble firing- 2006 GXP
Results 1 to 19 of 19
  1. #1 Trouble firing- 2006 GXP
    SE Level Member jpongratzgxp's Avatar
    Feb 2015
    I have 2006 GXP and I noticed that it starting getting issues with firing when it was cold outside (below freezing), but now I'm getting issues with it not firing off right away, anytime, especially when the engine hasn't been running for awhile. The engine turns over just fine, it just doesn't fire right away so I'm thinking there's some kind of blockage in the fuel lines or an issue with the spark plugs. Does anyone have any input on this?
  2. #2 Re: Trouble firing- 2006 GXP
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Tune up time.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  3. #3 Re: Trouble firing- 2006 GXP
    Feb 2015
    Well what would you recommend doing?
  4. #4 Re: Trouble firing- 2006 GXP
    Jan 2013
    Raleigh, NC
    How old are your plugs and wires? General maintenance up to date? Ever cleaned your throttle body? If you're not up to date with keeping your car running well, start there.
  5. #5 Re: Trouble firing- 2006 GXP
    Donating Users timboku's Avatar
    Montgomery, IL
    Gxp.plugs go to.**** around 80k, time.for a tune up
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  6. #6 Re: Trouble firing- 2006 GXP
    Agreed.
    Spend just a little time and money now to cover the basics then figure it out from there if something is still wrong.
    Clean the MAF sensor and throttle body, replace spark plugs if original and over 75k miles, always run 91+ octane fuel with those 5.3 or at the very least 89 octane. Run a can of fuel system cleaner through the gas tank.
  7. #7 Re: Trouble firing- 2006 GXP
    Feb 2015
    OK cool. I'll try that and let you guys know. And by the way my car has around 72k miles on it and I almost always run 91 octane in it.
  8. #8 Re: Trouble firing- 2006 GXP
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    when I got my 06 I had to change the plugs, Only the dod cylinders had deposits on them. That fixed the minor miss it had.
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  9. #9 Re: Trouble firing- 2006 GXP
    Feb 2015
    If I'm going to get new spark plugs is there any particular brand or model I should get or you recommend getting?
  10. #10 Re: Trouble firing- 2006 GXP
    I ended up getting NGK TR55.
    Seem to work just fine, tossed on new plug wires too. Car only has 60k but I wanted to get it done, especially since I had the transmission out.
  11. #11 Re: Trouble firing- 2006 GXP
    Feb 2015
    Does anyone know where the MAF sensor is in the GXP? I thought it was between the air filter and the engine.
  12. #12 Re: Trouble firing- 2006 GXP
    .......it is.
  13. #13 Re: Trouble firing- 2006 GXP
    Feb 2015
    Well that's where I thought it was. Do u know where it is?
  14. #14 Re: Trouble firing- 2006 GXP
    You can't miss it, it's filter and then MAF sensor.
    It has 5 wires coming out of the plug in.
  15. #15 Re: Trouble firing- 2006 GXP
    Feb 2015
    Wow you have a really clean engine, how do you keep it so clean? Also is that an after market air filter?
  16. #16 Re: Trouble firing- 2006 GXP
    That ain't his.
    He doesn't have a car.
  17. #17 Re: Trouble firing- 2006 GXP
    It's just a internet picture for a visual.
    Keeping a engine bay clean is easy though, wash it down and scrub it clean then just rinse it off every one and then.
    And he's right, I don't own a car anymore. I have a truck.
  18. #18 Re: Trouble firing- 2006 GXP
    Feb 2015
    Oh lol.
  19. #19 Re: Trouble firing- 2006 GXP
    And by truck he means power wheels
  1. 2006 Grand Prix trouble making left turns
    By Rose38478 in forum General Grand Prix Discussion
    Last Post: 04-20-2013, 07:38 AM
  2. not firing
    By jlt in forum General Grand Prix Discussion
    Last Post: 02-07-2012, 07:42 PM
  3. not firing
    By jem0103 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 06:24 PM
  4. 06 gp not firing on 2-4-6 cyl
    By melnrob in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2009, 05:19 PM
