Thread: Charge System Failure problems :(
Results 1 to 20 of 37
  1. #1 Charge System Failure problems :(
    Wichita
    I got the "Charge System Failure" message on my DIC last night. Get in the car to go to work this morning and it won't start. I go inside & grab some jumper cables and the alarm goes off. Well I managed to get the car jump started & I noticed the Voltage drops from 14 to as low as 11 when the car comes to a stop. So I had the Battery & Alternator checked out at AutoZone and they both checked out fine. I took the car home. Decided to try and remote start it just to see if it was already dead. It wouldn't start. I gave up and went inside and the alarm went off again. Wth?!
  2. #2 Re: Charge System Failure problems :(
    Aug 2011
    'Merica
    Maybe clean your battery terminals and check the grounds around the battery.
  3. #3 Re: Charge System Failure problems :(
    Wichita
    I cleaned the terminals real good. I'll check the grounds now.
  4. #4 Re: Charge System Failure problems :(
    Wichita
    It's really weird that this would happen. My battery is relatively new and the only thing ice touch in the car recently is the taillights.
  5. #5 Re: Charge System Failure problems :(
    Aug 2011
    'Merica
    ignition switch related? electrical is not my strong point.
  6. #6 Re: Charge System Failure problems :(
    Sep 2014
    Worcester, MA
    I'm super suspicious of the alternator. I had the exact same set of symptoms about a month ago (except for the AutoZone check), and a new alternator fixed everything.
  7. #7 Re: Charge System Failure problems :(
    Wichita
    Unfortunately it probably is ignition switch related.
  8. #8 Re: Charge System Failure problems :(
    Aug 2011
    'Merica
    Don't quote me on this, but I have heard of alternators testing good even though they are bad.
  9. #9 Re: Charge System Failure problems :(
    Wichita
    Quote Originally Posted by bobc455 View Post
    Because I know about Murphy's Law I won't rule out a bad alternator.
  10. #10 Re: Charge System Failure problems :(
    Aug 2013
    arlington, tx
    Did they test it on the car or did u take it off and have them put it on the machine?
  11. #11 Re: Charge System Failure problems :(
    Wichita
    Battery & Alternator were tested on the car.
  12. #12 Re: Charge System Failure problems :(
    Aug 2013
    arlington, tx
    Take the alternator off and have them run it on the machine. Have them test the battery with a load tester too just to rule out the battery.
  13. #13 Re: Charge System Failure problems :(
    Wichita
    ^^^I'll do that
  14. #14 Re: Charge System Failure problems :(
    Sep 2014
    Worcester, MA
    Is your alarm or remote-starter aftermarket?
  15. #15 Re: Charge System Failure problems :(
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Quote Originally Posted by Below Average Joe View Post
    Quote Originally Posted by luckyg817 View Post
    These. And if it tests fine the first time, ask them to test it a few more times. I have had alternators pass the bench test the first time or 2, but on the 3rd, 4th, 5th, etc time if finally fails.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  16. #16 Re: Charge System Failure problems :(
    Wichita
    Oreillys failed spectacularly to even get the battery tested. When I can I'll go elsewhere & test it again or just splurge & get a reman-Alternator. Can't afford a brand new one.
  17. #17 Re: Charge System Failure problems :(
    Enfield, CT
    Try amazon or rock auto. also you can find a low mileage used one at car-part.com
  18. #18 Re: Charge System Failure problems :(
    Wichita
    I'm going the RockAuto route, which sucks cuz that means I'll be without a car for several days.
  19. #19 Re: Charge System Failure problems :(
    Aug 2013
    arlington, tx
    How did they fail to test the battery? And just scrape together enough cash to get the one with a lifetime warranty on it. You won't regret it and it will be peace of mind.
  20. #20 Re: Charge System Failure problems :(
    Wichita
    Ordered through RockAuto and there was a Typo in my address when I placed the order. I called them to make an address change. All they could do was cancel the order & haver place a new order. I'm currently awaiting an order cancellation email. Oh boy what a day I've had.
  1. Charge System Failure
    By selyse in forum General Grand Prix Discussion
    Last Post: 11-18-2013, 07:39 PM
  2. Charge system failure light
    By Gohan77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2013, 10:24 PM
  3. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  4. Charging system failure w/HID's
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 03-12-2011, 12:37 AM
  5. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
