Thread: Lower tensioner bolt missing
Results 1 to 12 of 12
  1. #1 Lower tensioner bolt missing
    Feb 2013
    Missouri
    Hey guys, I need some help for a buddy of mine at work.
    He's missing the lower bolt of the tensioner. I'm assuming it's the lower bolt that holds the shock-like thingy to the tensioner assembly, since he has no tension. I haven't seen it in person, so that is what I gather. Does anyone know the bolt size\thread for that bolt? He's called everyone he knows to call and I'm basically his last resort, lol. Anybody able to help out?
    Thanks in advance.
  2. #2 Re: Lower tensioner bolt missing
    Antioch, IL
    Take the other bolt out go to the store and match the thread they are all the same
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Lower tensioner bolt missing
    Feb 2013
    Missouri
    They're the exact same? I'll bring it up to him and see what he says. I'd assumed he'd be smart enough to figure pull the other one if they were the same, but who knows. Either way, thanks.
  4. #4 Re: Lower tensioner bolt missing
    Antioch, IL
    Length might be different, but thread is the same. You would be suprised in the bay how many threads are the same, I have used the strut nuts for a couple things when the other nut fell into the bay black hole.
  5. #5 Re: Lower tensioner bolt missing
    Shock like thing to the tensioner assembly?
    There's bolts that hold the accessory tensioner bracket to the engine. The tensioner itself doesn't unbolt or com off the bracket assembly.
    The SC tensioner has a nut that holds it on stud over a nut that holds it to the cast iron bracket.
  6. #6 Re: Lower tensioner bolt missing
    Feb 2013
    Missouri
    The bottom bolt in that picture, I believe.
  7. #7 Re: Lower tensioner bolt missing
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    any impala's in the local junk yards?
    gm might have a exploded view/parts list for that
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  8. #8 Re: Lower tensioner bolt missing
    Feb 2010
    TN
    I would hit local junkyard
  9. #9 Re: Lower tensioner bolt missing
    Feb 2013
    Missouri
    He says he called everyone he knows to call in the state(and Kansas), and every junkyard that has something with this tensioner said it was already missing this bolt. I brought up pulling the top bolt out and he said it was a super PITA to get to, and that you have to pull the bracket. I wonder if Alldata would have the info? I guess I'll have to check, lol.
  10. #10 Re: Lower tensioner bolt missing
    Dammit..call me Scotty.
  11. #11 Re: Lower tensioner bolt missing
    Arizona
    Does it look like this?http://www.grandprixforums.net/threa...4-Belt-removal
    Im pretty sure its a metric size though nothing to complicated
  12. #12 Re: Lower tensioner bolt missing
    Feb 2013
    Missouri
    Yep, that's the one.
  1. s/c tensioner bolt size
    By 05gtpcg in forum General Tech Discussion
    Last Post: 09-28-2014, 02:37 PM
  2. Help Identify A 10mm Bolt Missing Its Hole...
    By 01Blackgtp in forum General Tech Discussion
    Last Post: 06-26-2014, 12:33 PM
  3. bolt broke off inside the tensioner assembly
    By glm859 in forum Shops and Community Heroes
    Last Post: 07-14-2012, 11:33 AM
  4. lower insulator bolt help please
    By DarkPassNger in forum Brakes/Suspension/Chassis
    Last Post: 07-17-2011, 04:35 PM
  5. Oil in the bolt valleys of the lower intake?
    By Pontiacman76 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-12-2010, 01:40 AM
