Thread: Engine Removal ?
Results 1 to 8 of 8
  1. #1 Engine Removal ?
    GTP Level Member joshv's Avatar
    canada
    anyone on here attempted to remove their ls4 ? i have removed other engines, and installed some, even put a 3.4/3.5 motor into a cavalier lol
    just looking to see if anyone has any tips or recommendations ?
    does anyone no if the engine/ engine and trans can come out of the top ? i do know you can pull the subframe, support the engine and separate the trans/ drop the engine threw the bottom but anyone pull from top ?
    thanks
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  2. #2 Re: Engine Removal ?
    Haven't seen anyone do one that I can remember. If it can come out the top, I believe it'll squeak a bit.
  3. #3 Re: Engine Removal ?
    SE Level Member CW2Lido's Avatar
    Pearl City Hawaii
    I pulled my LS4 out of the top of my grand prix, I have pictures if you would like to see them. It was pretty easy, yes there is some rubbing when the engine comes out but the hardest part is getting the back three bolts off your mounting plate and that one holding the tranny and engine together (18mm, required many socket extensions). I would do the engine then the tranny because you have way more room to remove the transmission. Just my words of wisdom! Yes it can be done!
  4. #4 Re: Engine Removal ?
    I'd like to see pics if Josh doesn't reply.
    If you can, please post them there. I'll be venturing into this over the winter.
    Thanks!
  5. #5 Re: Engine Removal ?
    Pearl City Hawaii
    Its easy as long as you take your time. Not sure if you have removed your exhaust ever but you will want to do your front header in order to give you clearance to bring the motor forward. The bolts are very stubborn since GM used a form of locktight on them and can break of very easy. I will try to post pics again but for some reason or other I don't seem to have the ability to do so. I have a lot of great pics of the engine coming out.
  6. #6 Re: Engine Removal ?
    new britain, ct
    you have to upload onto photobucket.com first, then link the pictures here CW2.
    07 Black GXP.
  7. #7 Re: Engine Removal ?
    Pearl City Hawaii
    Pm me and I will see what I can do to email pics out, I am not really good at posting on here and I dont use photobucket. The hardest part for me was stabbing it back in there and wishing I would have changed out my balancer before I put it back in. Other than that, it wasnt hard at all.
    Rakassan!
  8. #8 Re: Engine Removal ?
    Enfield, CT
    I wanna see pictures
  1. Engine Removal: Should I pull the engine or drop the sub frame?
    By acidcrashdburnd in forum General Tech Discussion
    Last Post: 03-13-2013, 03:29 PM
  2. Oil Pan Removal Possible With Engine In Car?
    By Skillet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-24-2011, 12:32 PM
  3. 3.8l engine removal
    By shauner01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2011, 06:00 PM
  4. engine removal
    By aubry118 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2010, 04:33 PM
  5. engine removal
    By stanwich in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-11-2008, 11:23 PM
