Thread: 06 gxp temp gauge not working.
Results 1 to 4 of 4
  1. #1 06 gxp temp gauge not working.
    Mar 2014
    Angola, IN
    Alright I looked on here for similar issues and couldn't find any that had said how they solved the issue. I have a 06 gxp with 98,000 and the temp gauge is not working. Started off by replacing the temp sensor and that didn't work. Any other ideas? Also I'm getting the a/c off for engine protection because of this I think.
  2. #2 Re: 06 gxp temp gauge not working.
    May 2014
    Seymour, Tn
    Check the piece that plugs into the sensor and wires. I recently had this problem and it was the plug and not the sensor.
  3. #3 Re: 06 gxp temp gauge not working.
    Illinois
    I had a similar issue. Turned out to be the outside air temp sensor. Located right front behind the grill, connection was loose. Fixed for free!
  4. #4 Re: 06 gxp temp gauge not working.
    Mar 2014
    Angola, IN
    Sorry guys i thought I posted how I fixed this issue. Turned out being corrosion on a battery terminal. After changing the temp sensor and harness that did nothing so I put the old one back in and cleaned the battery terminals. that fixed it right away. Very strange that can cause small issues like that but that's how I fixed it.
  1. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  2. Temp Gauge not working
    By Alcatraz in forum General Tech Discussion
    Last Post: 04-08-2013, 08:57 PM
  3. Temp Gauge not working...Aeroforce says 180
    By wa04compg in forum General Tech Discussion
    Last Post: 04-02-2012, 06:29 AM
  4. Temp Gauge stopped working???
    By GXP05er in forum 5.3L V8 (LS4)
    Last Post: 08-10-2010, 07:37 PM
  5. Temp gauge not working
    By gabsgrammy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2010, 06:04 PM
