west springfield
Yes I changed the hdm module
So some more updates, hopefully related.
I started my car a Month or two ago, it said charging system failure. Battery save mode kicked in. I also noticed all my tire pressure s read at 128 psi....yes; 128. The car shortly after shutting off would not start back up.
Had it towed to a mechanic. Said alternator had to be replaced. Got it replaced and drove it home. Went to drive it out of my driveway today and the same eexact issue happened and cannot get my car to start. It wants to turn over but won't
Tried jumping and charging battery
Charging system failure could be your battery current sensor. It's located on your negative battery cable. I had that failure and the sensor had a hole in the bottom of it. I don't know if that will help but it's free to look at.
