Thread: 06 GXP No Cruise Control
Results 1 to 5 of 5
  1. #1 06 GXP No Cruise Control
    GT Level Member fisher580's Avatar
    Jan 2012
    Dyersville, Iowa
    I have no Cruise control, started randomly then all together stoped working, now on a rare occasion, I cant remember last time, it will work.
    When it doesn't work:
    -the hud goes into the speed set/cruise set screen for maybe half a second then goes back to normal with no cruise control.
    -if im not touching the gas when I hit cruise it will rev about 500 rpm then back down.
    Things I have Changed recently:
    -Led Reverse/license plate/interior Lights (has worked since)-
    Played with Diablosport on diff. tunes (makes no diff.)
    Codes I throw:
    Current - Low Oil pressure/opsu range not optimal or w.e (opsu is broke, don't worry I have oil pressure)
    Past - Throttle position actuater range/performance;
    ^this is what I think caused it, I only seen the code once and it was around the time the cruise stopped working, but I cleared it and it never came back, kind of like my cruise never came back
    Hopefully my ls2 throttle body will fix this in the near future
    also mods are in sig
    Thankyou in advance
    2001 Grand Prix GTP Coupe - Black-SOLD
    -SOLD
    2006 Grand Prix GXP - That Purplish dark red color
    -FWI, DiabloSport Trinity, and Trans. Cooler - - 6.8 @ 208 mph LOL
  2. #2 Re: 06 GXP No Cruise Control
    Arizona
    turn off traction control then turn on your cruise control, Also fix your OPSU- get a new sensor and pluck the OPSU filter out to clean it and re-install.
  3. #3 Re: 06 GXP No Cruise Control
    Jun 2013
    Metro Detroit
    Check your connection to your 3rd brake light. If that circuit isn't closed, cruise will not work.
  4. #4 Re: 06 GXP No Cruise Control
    Dec 2011
    Southern Wisconsin
    The diablosport tune for the GXP makes the cruise control act goofy, as stated you will need to turn off trac control for it to work. You can leave the stabilitrac on.
    06 GP GXP "Charlize". TEP Street/Strip trans w/3.29 gearing. 20k trans cooler - standalone. DiabLew Tuned 91 oct. ZZP Catted downpipe, Magnaflow Cat-back.
    '13 Chevy Cruze 2LT M6.
  5. #5 Re: 06 GXP No Cruise Control
    Jan 2012
    Dyersville, Iowa
    sorry for the late response i havent had internet for a few days, but it works great TC off, i guess i just never noticed that was when it worked
    -SOLD
  1. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:19 PM
  2. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum General Tech Discussion
    Last Post: 07-30-2012, 07:16 AM
  3. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2012, 07:14 AM
  4. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  5. Is this what you buy to fix cruise control?
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 05-16-2009, 12:08 PM
