Thread: Gauges, radio, etc off while driving
Results 1 to 11 of 11
  1. #1 Gauges, radio, etc off while driving
    Apr 2015
    Houston
    I went grocery shopping earlier today. After I got back to my car, I started her up and just left. It was busy as hell and just wanted to get out of there. Anyways, it wasn't till a couple of minutes later till I realized my radio was off. I looked at the gauge cluster and noticed nothing was working. None of the gauges were working, no radio, no HUD, nothing!
    At the first red light, I turned off my car so I could start it back up and hopefully everything would work again, BUT... it didn't friggin start!!! I turned the key and nothing would happen. No click, no nothing! After the 20th time or so it finally started, right as the light turned green. (phew) Everything worked again.
    What could this be? I know about the ignition switch recall so that's the first thing that came to my mind. I bought it used so I don't know if the previous owner had the ignition switch replaced or not, but I know I didn't. Could the ignition switch be the culprit here? Has anyone had this happen before?
  2. #2 Re: Gauges, radio, etc off while driving
    could be a busted off ground, or breaking off. tranny bell housing bolt with the bat neg cable are a few more grounds, make sure they are tight clean not coming off the eyelets.
    before that, make sure the battery terminals are clean and tight.
  3. #3 Re: Gauges, radio, etc off while driving
    Apr 2015
    Houston
    I know the battery terminals are clean and tight, but I didn't check any other grounds. I will tomorrow. Thanks. You would think this to be more likely than the ignition switch?
  4. #4 Re: Gauges, radio, etc off while driving
    sounds more like a bad ground to me, never heard of the ignition harness causing any of that stuff.
    what year is your car?
  5. #5 Re: Gauges, radio, etc off while driving
    Apr 2015
    Houston
    It's a 2006. Got 261k miles. Gulp!
  6. #6 Re: Gauges, radio, etc off while driving
    damn, it used to deliver pizzas or something? lol i got 240.000 on the body of my 98 regal. stuffs still holding up somewhat lol
  7. #7 Re: Gauges, radio, etc off while driving
    Topeka, KS
    My car has done this when the alternator failed while going down the road. Your car will run as long as you have your foot on the gas. I Drove it 20 more miles and coasted into town into a parking lot.
  8. #8 Re: Gauges, radio, etc off while driving
    Donating Users
    Kansas City
    Honk the horn.
    Seriously.
    If it sounds like it's dying or it's quiet, it is a voltage issue.
    Have the battery and alternator tested (they're easy to remove so take them to a parts store and have them ran on their machines)...see what that gets you.
    2012 Buick Regal Premium1 Turbo - White Diamond Tri-coat - 20% Tint - 5k HID Head/Fog Lights - ZZP CAI
  9. #9 Re: Gauges, radio, etc off while driving
    they got battery testers that test the voltage and load on the battery, no need to take anything off to be tested.
  10. #10 Re: Gauges, radio, etc off while driving
    Apr 2015
    Houston
    Thanks guys. But I've got yet another new problem with the car. At this point I feel like blowing the piece of **** up with some tannerite
  11. #11 Re: Gauges, radio, etc off while driving
    Arizona
    the harness at the fusbox comes loose causing intermittent issues like this. Grab a 7mm and tighten those bolts at the fuse box see if it helps
  1. MONSOON radio thinks it's a BOSE radio now...
    By industrialfish in forum Audio, Security & Visual Electronics
    Last Post: 06-02-2016, 06:00 AM
  2. Got a jump start... now my gauges die and my radio shuts off and...
    By bobc455 in forum General Tech Discussion
    Last Post: 02-02-2015, 01:48 PM
  3. Gauges reset while driving
    By RICHEYSGTP in forum 04+ Specifics
    Last Post: 09-15-2013, 02:50 PM
  4. When your driving...
    By jer206 in forum General Grand Prix Discussion
    Last Post: 04-28-2012, 10:40 PM
  5. while driving, BOC!
    By fst in forum The Rant Forum
    Last Post: 02-04-2008, 10:47 AM
