Thread: Misfire
Results 1 to 5 of 5
  1. #1 Misfire
    SE Level Member GXPrunner06's Avatar
    Jan 2013
    Romulus, MI
    Its been in the negatives here in michigan for the past 2-3 days. This only happens on the way home from work at night. But I will be driving down 94 at 40-50 because of the snow/ice and i hear the DOD kick on. I'll drive for some time like this. When I try to accelerate it sounds like i'm misfiring and it won't gain speed. Code came on PO301 (cylinder 1). It feels like the car gets stuck in DOD mode. Car operates normally any other time.
    Could it be because of the weather? Vehicle had a tune up in October.
    2006 GXP| Pioneer 8400 | LED Interior Lights | Daily Driver | Diablosport 91 octane tune/DOD disabled
    2002 GTP 40th Anniv.| ubend delete | zzp 1.0 pcm | K&N full intake
  2. #2 Re: Misfire
    Well, if you know its a cylinder 1 misfire, then start to diag the issue.
    Pull the plug, check the condition, check for a crack. Inspect the wire.
    Swap the coil with cylinder 3 or cylinder 5 on that same bank and see if the misfire follows. If it does, you know the coil is bad. Same can be done for wires and spark plugs.
  3. #3 Re: Misfire
    Jan 2013
    Romulus, MI
    I will do this when I change the oil today but it hasn't done it since....weird though
    Sent from my SCH-I535 using Tapatalk
  4. #4 Re: Misfire
    Wichita
    Could be your plug is covered in oil and isn't firing at all below certain temps.
  5. #5 Re: Misfire
    Jan 2013
    Romulus, MI
    I know cylinder 1 has a problem with that because of dod
  1. Maybe a misfire?
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2010, 04:24 PM
  2. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  3. 99 GT Misfire on cyl 6.
    By mazzafamily in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-28-2009, 10:12 AM
  4. 97 GTP Misfire
    By ThePrimerSuspect in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 10:42 AM
  5. Need help with misfire 98 gtp!
    By Viperhunter in forum General Tech Discussion
    Last Post: 10-08-2009, 02:39 PM
