Thread: Cylinder #5 misfire
Results 1 to 20 of 21
  1. #1 Cylinder #5 misfire
    Wichita
    Really stumped on this one. I've checked the plug & it checked out fine. As does all the wiring. What could be causing this?
  2. #2 Re: Cylinder #5 misfire
    Have you replaced the plug, coil, plug wire? Or just "looked" at them?
  3. #3 Re: Cylinder #5 misfire
    Wichita
    I checked for fluid & corrosion on the plug as well as cracks. The spark plug was clean & undamaged. As was the plug wire.
  4. #4 Re: Cylinder #5 misfire
    I'm saying I've had plugs and wires that looked fine but are bad...swap the coil and injector and see if the missfire follows...
  5. #5 Re: Cylinder #5 misfire
    Wichita
    I will do that.
  6. #6 Re: Cylinder #5 misfire
    GT Level Member aligater's Avatar
    london ontario canada
    move one part at a time to know which one is failing, I'd try the injector last. Also if your using your aeroforce as the scanner, check with an actual scanner as I have had one lie, saying cyl 1 missfire only to find out it was #2 cyl. Try plug, wire, coil etc. and see if the miss follows the part you've swapped out.
    GL
  7. #7 Re: Cylinder #5 misfire
    Wichita
    I'd love to swap one part at a time, but I no longer have my own scangauge.
  8. #8 Re: Cylinder #5 misfire
    Wichita
    New plug and plug wire. Still misfiring. That leaves, coil, injector, PCM, or something else. I'm tired of this car.
  9. #9 Re: Cylinder #5 misfire
    Is it C.O.P.? Move the injector to one cyl and the coil to another and see if it moves.
  10. #10 Re: Cylinder #5 misfire
    Wichita
    What is C.O.P?
  11. #11 Re: Cylinder #5 misfire
    coil over plug
  12. #12 Re: Cylinder #5 misfire
    Wichita
    Yes
  13. #13 Re: Cylinder #5 misfire
    Wichita
    On a brighter note. the guy who scanned my car said this is putting too much load on the engine and that the tranny wouldn't last much longer.
  14. #14 Re: Cylinder #5 misfire
    Swap the coil. My bet is the coil is shot.
  15. #15 Re: Cylinder #5 misfire
    Wichita
    I did get a crazy unusual improvement in mpg after putting a new plug and wire on cylinder #5. Went from 18.5 to 25.3
    Last edited by SDGTP99; 01-23-2013 at 08:10 PM. Reason: Making typos cuz Im im a bad mood.
  16. #16 Re: Cylinder #5 misfire
    Wichita
    Is aisfire really going to make my tranny temps go up? Temps are reaching up to @221.
  17. #17 Re: Cylinder #5 misfire
    Wichita
    New coil didn't help.
  18. #18 Re: Cylinder #5 misfire
    Trans temp shouldn't matter even if it's misfiring. Try moving the injector next? DOD messed up maybe?
  19. #19 Re: Cylinder #5 misfire
    Wichita
    Idk, maybe. I'm calling the dealership in the morning. GXP's under warranty so they can fix it. Cuz I've had enough of this cars shenanigans.
  20. #20 Re: Cylinder #5 misfire
    Last thing would be the injector, or reduce the plug gap some, even do a compression test.
  1. Misfire cylinder 4
    By RamairGTP2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2012, 06:17 AM
  2. Misfire on cylinder 3 and 4
    By bhuyser in forum General Tech Discussion
    Last Post: 09-08-2011, 11:17 AM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
