Thread: stuck plug<<<
Results 1 to 8 of 8
  1. #1 stuck plug<<<
    Jun 2012
    Cedar Rapids, Iowa
    so im changing my spark plugs and i got 5 of them no problem what so ever... but 3 of them o my god!! wont come out. so when i was unscrewing them they would get loose but then it hits like a patch of rust or something and then it just tightens up and wont move. and its the front 2 corner ones and the back far right corner driver side.. any advice????
  2. #2 Re: stuck plug<<<
    Aug 2011
    'Merica
    i assume you have GXP?
  3. #3 Re: stuck plug<<<
    back it out till it stops, spray some lube at the threads, then turn it back in and out, working it in and out till it comes out, or the threads may rip out of the head.
  4. #4 Re: stuck plug<<<
    Jun 2012
    Cedar Rapids, Iowa
    yes gxp
  5. #5 Re: stuck plug<<<
    Aug 2011
    'Merica
    do what scott said. do not wrench on it or the head will strip.
  6. #6 Re: stuck plug<<<
    Dec 2012
    Where 4T65E's were born
    On the topic of spark plugs, what plugs will work best for my 3.8 series II N/A engine? I know there are posts about this, which I have read, but they say "stock" plugs as far as I know. Well mine have been replaced with what I believe are cheap plugs at a corner service center, so I'm not sure what I should look for. Will replacing then with the recommended plugs get me more power/efficiency? I'm not very impressed with mine compared to our impala with the 3.8 with original plugs at 109k miles.
    Also I tried to pull my plug wire boots off the plug to get a look, but the metal clip in the boot tore off...Never ended up being able to see what was in it, didn't care much after the spark plug wire failure.
    Sold.
  7. #7 Re: stuck plug<<<
    ^ AC Delco Iridium
    04 Comp G.
  8. #8 Re: stuck plug<<<
    Pennsylvania
    02Navyblue: Wrong forum. But REDCOMPG has the right of it: The guy at the parts counter will hand you the correct plugs if you just ask for "stock."
  1. 2008 Base model plug and plug wire swap
    By MS1227 in forum 04+ Specifics
    Last Post: 12-06-2012, 06:14 PM
  2. Car stuck in park, key isn't stuck though
    By capitalcrew in forum General Tech Discussion
    Last Post: 05-03-2012, 10:28 PM
  3. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  4. stock antenna plug to universal plug?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2012, 10:25 PM
  5. How Come My Car Gets Stuck In This Vid.....
    Last Post: 12-17-2008, 02:18 AM
