Thread: Miles per gallon gxp
Results 1 to 20 of 24
  1. #1 Miles per gallon gxp
    Jun 2012
    Cedar Rapids, Iowa
    I dont know if anybody has ever had a problem with mpg. im curently avg. between 11-13 mpg . i took it to professional muffler because this all happen right after i got my new magnaflow exhaust on and they said it was the catalytic convertor and i just got that done yesterday and doesnt seem to be a big help atill getting only 13mpg. but first i took it to auto zone and they told me a 02 sensor but then prof. muffler told me the catalyic convertor. so someone help plzzzzz!!!!
  2. #2 Re: Miles per gallon gxp
    Did you change the o2 that was bad then?
  3. #3 Re: Miles per gallon gxp
    Jun 2012
    Cedar Rapids, Iowa
    i didnt because they told me nothing was wrong with it. but i might just go get a 2nd look somewhere else
  4. #4 Re: Miles per gallon gxp
    If it pulled a code, something is wrong.
    Go get the code read again and post it here.
    And don't go "get a 2nd look elsewhere", just go to your local parts store and get the code read for free.
    I live here. DirtDog's Avatar
    Jun 2012
    Well the 02 could definitely make the fuel economy go way down. It helps with fuel to air ratio somehow.
    Edit: also if u haven't u could change spark plugs. The ls4's love the NGK TR6IX plugs. I have some ordered just waiting for them to come in for mine
    Sent from my DROID RAZR using Tapatalk 2
  6. #6 Re: Miles per gallon gxp
    Quote Originally Posted by marines542 View Post
    Somehow....
    By telling the motor what's going on in the exhaust?
    Yeaaaaa.
  7. #7 Re: Miles per gallon gxp
    Jun 2012
    Cedar Rapids, Iowa
    sounds good will do. thanks guys
  8. #8 Re: Miles per gallon gxp
    Jun 2012
    Cedar Rapids, Iowa
    where did you order your plugs
  9. #9 Re: Miles per gallon gxp
    Google could tell you...but nooooooooooooooooo.
  10. #10 Re: Miles per gallon gxp
    Jun 2012
    Cedar Rapids, Iowa
    and 8 of them?
  11. #11 Re: Miles per gallon gxp
    Quote Originally Posted by Alsafi92 View Post
    and 8 of them?
    Ok, seriously?
  12. #12 Re: Miles per gallon gxp
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Nope, you need 1 spark plug.
    Your GXP has the same engine as my Push Mower.
  13. #13 Re: Miles per gallon gxp
    Jun 2012
    Cedar Rapids, Iowa
    jeez just a simple question dont need to get your undies in a bunch
  14. #14 Re: Miles per gallon gxp
    Google
    Like I said.
    Seems like you need to learn quite a bit about your platform.
  15. #15 Re: Miles per gallon gxp
    Jun 2012
    Cedar Rapids, Iowa
    yeah i do. this is my first pontiac. i come from a sti and a eclipse... so a bit different.
  16. #16 Re: Miles per gallon gxp
    It's still a car.
    It even says V8 on the trunk lid.
    It's no different than your STi and Eclipse that needed 4 spark plugs because they are...SHABAM! Four cylinder engines.
    Jun 2012
    I got mine from oreillys. They were cheaper than online by. 25 cents per plug.
  18. #18 Re: Miles per gallon gxp
    Jun 2012
    Cedar Rapids, Iowa
    i know right after i typed that i thought to my self what a stupid question.... ):
    Jun 2012
    Also the plugs I listed above are 1 heat range cooler than stock but over on gmls4 everyone says the engine runs better with em and less knock. I've researched plugs and wires a lot for em...and I also ordered msd wires. I have some links for info I'll send later when I get on computers
  20. #20 Re: Miles per gallon gxp
    Jun 2012
    Cedar Rapids, Iowa
    awesome dude thanks ill keep in contact
  1. 3 Gallon Air Compressor
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2012, 08:10 PM
  2. Hours Per Gallon/Gallons Per Hour
    By Chad Gervais in forum General Grand Prix Discussion
    Last Post: 08-26-2012, 08:38 PM
  3. miles per gallon?
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2010, 06:59 AM
  4. How many gallon fuel tank
    By kjclawson in forum General Tech Discussion
    Last Post: 11-13-2009, 06:30 PM
