Thread: LS4 gauge install question
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 95
  1. #1 LS4 gauge install question
    I live here. DirtDog's Avatar
    Jun 2012
  2. #2 Re: LS4 gauge install question
    Yoga city
    no idea, if it does, let me know how it turns out.
    Jun 2012
    Yea I'll let y'all know. I just wanted some input from more experienced gauge install people. The oil pressure sensor us very easy to get to as well. It's right below the TB
    Sent from my DROID RAZR using Tapatalk 2
  4. #4 Re: LS4 gauge install question
    GTP Level Member joshv's Avatar
    canada
    i tired with a few buddies and failed haha, but easiest way to go is to buy and oil filter adapter it screws in were ur oil filter is and then u screw the oil fiulter on to it and u go from there.. it's all through glow shift
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
    Jun 2012
    Quote Originally Posted by joshv View Post
    I'll look that up online later when I get onto a computer and look. My thing is the oil filter is right beside oil pan so adding an insert would put it close to the ground
  6. #6 Re: LS4 gauge install question
    Yoga city
    i dont know i feel there would be enough clearence there, adds maybe an inch.
  7. #7 Re: LS4 gauge install question
    Jun 2012
    ok anyone know which one i would need? they all have different thread types and all
    Oil Filter Sandwich Adapters
  8. #8 Re: LS4 gauge install question
    Jun 2012
    ok so if i can get the correct filter sandwich adapter i am going to install an oil pressure gauge, oil temp gauge, and a coolant temp gauge with an aero force gauge in the top air vent next to drivers side door. If anyones got any better gauge i should install instead of the above let me know. and if anyone knows the correct oil filter sandwich adapter than let me know...if not im gonna call em tomorrow
  9. #9 Re: LS4 gauge install question
    Oil temp gauges are not needed, the oil doesnt ever get hot enough to ever worry about anything.
    The aeroforce does coolant temp, would be a waste to buy a seperate gauge.
  10. #10 Re: LS4 gauge install question
    Jun 2012
    yea i knew the aeroforce gauge does but i cant think of what gauges to add to the pillar pod beside oil pressure and aeroforce and they only make a pod with three spots and i dont really want one just empty...any better ones to put. i have no SC so cant really put a boost gauge
  11. #11 Re: LS4 gauge install question
    Arizona
    IF youre hell bent on oil presseure which IMO is a waste as the PCM would shut down the engine anyway if low oil pressure ever happened, but since the one you want is electric you shouldnt have to modify anything, just wire the sender fore gauge into the OPSU pigtail. and bam theres your signal output. honestly a aeroforce is all you would need to monitor the things you need to know.I would be looking at something like this 3383.jpg
    simple and effective for everyday driving. My old GTP had a 3 pod on the A pillar and there cool at first but having that **** there everyday gets kind of annoying.
    Jun 2012
    I read a couple threads on gmls4 and 1 on ls1 tech that they tapped into the stock sensor which is super easy to get to and it was reading wrong on the gauge. But I wanna get a pillar gauge pod cause I'm not a big fan of the in vent look. And the only pod available is a 3 gauge pod. So basically I want some useful gauges I can put in along with the aeroforce
  13. #13 Re: LS4 gauge install question
    Arizona
    Gotcha well another option is autozones single and double universal gauge pods you could purchase for 15 bucks and then mold them on your a pillar I did that on my gtp really was easy to do and came out really good that way you don't have to buy a ****load of gauges JUST to fill up space
  14. #14 Re: LS4 gauge install question
    Jun 2012
    im terrible with molding things. i tried with a heat gun and a practice pillar i got from junk yard and failed miserable. but if i could find 1 more useful gauge than ill be fine. im pretty sure an oil pressure and aeroforce gauge are gonna be a good buy and easy to install both after checking out glowshift.com. i figured out which sandwich adapter i would need so thats solved. so really i only need 1 more gauge
  15. #15 Re: LS4 gauge install question
    canada
    would you mind sharing which adapter is needed !! ?? hahah thanks. if you got one space there is allways a second aero force u could use.. i like the air vent look.
    Jun 2012
    You will need the 13/16-16 Oil filter adapter.
    That's what they sent me. I already ordered it since shipping was free. I'm gonna wait till I get all the gauges and change the oil and all at once.
  17. #17 Re: LS4 gauge install question
    Jun 2012
    ok so what about a fuel pressure guage? ive decided im still gonna go with the 3 gauge pilliar from zzp just cause i like the way the looks way better than the one in the vent on drivers side. and the fuel pressure one looks very easy to install. As far as i can tell itll just screw onto the fuel rail and obviously put some Teflon tape on the threads to prevent leaks just like on the oil pressure electric sender unit
    this is the fuel pressure guage im looking at. comes with everything needed
    Tinted 7 Color 100 PSI Fuel Pressure Gauge
    and the oil pressure one
    Tinted 7 Color Oil Pressure Gauge
    oil filter sender adapter sandwich thingy
    Oil Filter Sender Adapter - 13/16-16 Thread
    and i figured for 10 more bucks id grab this just to save me a little wiring
    7 Color Gauge Series Extended Sensor Wiring Harness
  18. #18 Re: LS4 gauge install question
    Arizona
    You have a returnless fuel rail your only option is to tap the rail for that.
  19. #19 Re: LS4 gauge install question
    Yoga city
    you bette have some write ups going on after this.
    Jun 2012
    Quote Originally Posted by 91parkave View Post
    Son of a bit*c. Well that ones out...
    And yea I'll take pics and do a write up on the ones I install for ya
  1. help me install my boost gauge!
    By des19 in forum General Tech Discussion
    Last Post: 08-22-2012, 06:01 AM
  2. Oil pressure gauge install help please
    By szalajka05 in forum Audio, Security & Visual Electronics
    Last Post: 12-18-2011, 07:54 PM
  3. Gauge install help...a-pod
    By blortz in forum Audio, Security & Visual Electronics
    Last Post: 07-31-2011, 11:26 AM
  4. Gauge pillar install
    By jdmgtp in forum General Tech Discussion
    Last Post: 06-17-2010, 06:17 AM
  5. AFR gauge install
    By amwhitey in forum General Tech Discussion
    Last Post: 02-03-2010, 01:25 PM
