Thread: Have a few DTC's P0121, P0521, P0523
Results 1 to 7 of 7
  1. #1 Have a few DTC's P0121, P0521, P0523
    Wichita
    I have an idea what is causing my car to run like pooh;
    -DTC P0121, which is for a bad TPS. I just ordered a new TB to fix this issue.
    -DTC P0521 & P0523 are both for Low oil pressure/low oil level/faulty electronics.
    I haven't done much to the car lately except an oil change, and the oil level is fine. Could a bad throttle body be causing all of these problems? Could it cause the engine to constantly switch from 4 to 8 cylinders, consume oil & lose pressure? I honestly don't know. But, when driving it does feel like the car is either knocking, switching from 4 to 8 cylinders or shifting. Any help at all will be appreciated. =]
  2. #2 Re: Have a few DTC's P0121, P0521, P0523
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    did you check your engine level....
  3. #3 Re: Have a few DTC's P0121, P0521, P0523
    Oct 2012
    Fort Wayne, Indiana
    engine oil level
  4. #4 Re: Have a few DTC's P0121, P0521, P0523
    Wichita
    I did. Oil level is fine. Guys on LS1Tech say the P0521 is caused by a bad Oil Pressure sensor. Still unsure what caused the P0523.
  5. #5 Re: Have a few DTC's P0121, P0521, P0523
    Wichita
    Replaced oil Pressure sensor. Car suns a wee bit better. Still acts like its missfireing and the tailpipes are turning black fast. Doubt that's caused by a bad TPS. I bet I have a nasty consumption problem...
    SE Level Member TML529's Avatar
    May 2008
    Chicago
    Had my Throttle body replaced under warranty around 45k and just had my oil pressure switch replaced.
  7. #7 Re: Have a few DTC's P0121, P0521, P0523
    Wichita
    I replaced both out of pocket. Not sure I needed to. Codes went away after cleaning TB and adding a quart of oil. =\
  1. P0521 Check Engine Light!!
    By hazards280 in forum 5.3L V8 (LS4)
    Last Post: 05-17-2011, 08:57 AM
  2. p0121 code
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2010, 10:13 PM
  3. P0121 code repeatedly
    By Grossman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2010, 01:41 PM
  4. P0121
    By corsagtp in forum Introductions/Noob Questions
    Last Post: 12-09-2009, 07:39 PM
  5. Troubleshooting Help! p0120 & p0121
    By Lawngoose in forum General Tech Discussion
    Last Post: 10-25-2008, 05:10 PM
