Thread: Idler pulley bearing part number needed.
Results 1 to 4 of 4
  1. #1 Idler pulley bearing part number needed.
    Jun 2011
    Illinois
    I have the annoying engine whine issue. I've changed the power steering pump, but not it. I feel that it's the ribbed idler pulley just in front of the pwr steering pump. I removed the pulley, but absolutely no part number on the bearing. I pressed the bearing out, took measurements, and still no luck. I rather just press in a new one than pay $60 for a new pulley. Looks like GM through together what ever they had laying around. This is not your typical bearing. Does anyone have a bearing number that will work? Thanks!
  2. #2 Re: Idler pulley bearing part number needed.
    This should fix up any pulley part numbers etc that you need.
    http://www.grandprixforums.net/commo...ets-39796.html
    Make sure you use series II. The S I stuff is for the cars that got 3.8's in 92. Aka non GP's
  3. #3 Re: Idler pulley bearing part number needed.
    Jun 2011
    Illinois
    I actually need the bearing number that they use in the pulley. The pulley part numbers listed don't add up either.
  4. #4 Re: Idler pulley bearing part number needed.
    No one buys the bearing seperately to my knowledge. The pulley part numbers work. I know..because myself and others have bought tons of them. Which pulley is the issue?
  1. MAF part number for 02 gtp
    By jonygtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2012, 04:44 PM
  2. Brake Pad Part Number
    By von in forum General Tech Discussion
    Last Post: 01-13-2012, 05:23 AM
  3. Part number for 3.5 inch Tensioner pulley?
    By Wotgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2011, 05:43 AM
  4. part number for oversize SC tensioner pulley?
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 11:45 PM
  5. Need a Part Number....
    By webracin in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2008, 01:54 PM
