Thread: ignition coil pack swap
Results 1 to 18 of 18
  1. #1 ignition coil pack swap
    Apr 2012
    Louisiana
    i have a 06 gxp and i need to change the coil pack on cylinder 7. Does anybody have a diagram layout of the cylinder placement? & Does anybody know if theres any specific instructions on how to change it?
  2. #2 Re: ignition coil pack swap
    Cylinders should start on teh driver side front as 1, 2 is passenger side front. Going in that order, the back one on the driverside should be #7
    Your coils should be mounted on top of the valve cover IIRC and therefore it's easy..I think it's unplug the harness to pack and pack from plug wire, then it's likely two 10mm bolts.
    In case i'm wrong.. please know..I totally shot all that from the hip.
  3. #3 Re: ignition coil pack swap
    GT Level Member Mikey Bonefas's Avatar
    May 2012
    Waterloo, IA
    ^usually hes dead on to so give it a try lol
  4. #4 Re: ignition coil pack swap
    a 8 cylinder should be
    closest to the bumper, (reading from the pass side of car to the driver side) 1-3-5-7
    rear of engine 2-4-6-8
    your coils should be right atop the spark plugs, mounted on the valve covers.
  5. #5 Re: ignition coil pack swap
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    The GXP is rear wheel drive?
  6. #6 Re: ignition coil pack swap
    my google search showed it being transverse aka fwd.
    I live here. DirtDog's Avatar
    Jun 2012
    Not forsure but check the repair manual on gpona. I've seen it one there before
    Sent from my pager using Morse code. ... .. ... ....
  8. #8 Re: ignition coil pack swap
    Dec 2008
    ****'s Creek
    OK so if its FWD you said it correctly, Bill described a longitudinal set up like a RWD. I wasn't sure if the GXP was FWD or RWD, I remembered reading that the Holden that GM built in Australia was RWD.
    Jun 2012
    Here is a picture I have in my gallery of ls4 information. If it helps any
  10. #10 Re: ignition coil pack swap
    Dec 2008
    ****'s Creek
    OK that shows a RWD layout.
    Jun 2012
    That's the image I got off ls1tech a while back. Is that not correct
  12. #12 Re: ignition coil pack swap
    Front of motor faces pass. side of car.
    Jun 2012
    Yes I knew that lol. Just the way pic was. But if u rotate it clockwise then it would be right. That's the way I pictured it
  14. #14 Re: ignition coil pack swap
    Dec 2008
    ****'s Creek
    LOL I assumed "front" meant front of car. Yes, this diagram is correct. Front of motor is where the belts are.
  15. #15 Re: ignition coil pack swap
    Hahaha... why the heck would I think the way I did... See, it's lucky I put the disclaimer on it. Turn what I said clockwise and it'll make sense.
    Jun 2012
    My bad. I'll clarify that better next time :banghead:
  17. #17 Re: ignition coil pack swap
    Worked for me..and since #7 is the front driverside pack..he's in luck.
    Jun 2012
    The coil packs for this car is expensive as f***
  1. coil pack
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 11-18-2012, 02:57 PM
  2. Coil pack question
    By Logan541 in forum General Tech Discussion
    Last Post: 12-31-2011, 08:45 PM
  3. coil pack
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-13-2010, 12:22 AM
