Thread: Oil change through the dipstick?
Results 1 to 13 of 13
  1. #1 Oil change through the dipstick?
    SE Level Member jstevanus's Avatar
    Feb 2010
    Michigan
    I've never heard of the dip stick oil change method, so I need some opinions please. I discovered it today through the deal HERE on a device that does it. If the deal is dead by the time you see this, there is another one HERE for reference. I then found a basic how-to on the process HERE. The benefit to this, is I don't have to climb under the car. My main question, is can I get to the oil filter without jacking the car up? This is on a Grand Prix GXP, by the way. Any help is greatly appreciated!
  2. #2 Re: Oil change through the dipstick?
    I can't imagine that working very well...but to each their own.
  3. #3 Re: Oil change through the dipstick?
    GT Level Member Utter99's Avatar
    Warsaw indiana
    if you have a magnetic drian plug id hope you would do it the original way... this looks like it wold leave a lot of oil still in the pan. . but like blue said to each their own
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  4. #4 Re: Oil change through the dipstick?
    Feb 2010
    Michigan
    Quote Originally Posted by Utter99 View Post
    Hey I have no clue. Some articles said it was better because it pulled out more oil than the conventional way. I forgot about the magnetic drain plug part, that's a good point. But, since the GXP has an aluminum block, it wouldn't really magnetize anything would it?
  5. #5 Re: Oil change through the dipstick?
    Quote Originally Posted by jstevanus View Post
    The magnetic drain plug is to collect the actual shavings that are attracted to the magnet from re-circulating back into the rotating assembly....not to be attracted to the block.
  6. #6 Re: Oil change through the dipstick?
    GTP Level Member Rico's Avatar
    Apr 2009
    Fort Worth TX
    That's a heck of a rack you got there!
    It's a CUMMINS Dodge not a Dodge Cummins
  7. #7 Re: Oil change through the dipstick?
    Feb 2010
    Michigan
    Quote Originally Posted by Rico View Post
    Ha. thanks! It's actually just a picture of a girl that my company took pictures of. Those things are ginormous trust me! At least J or K cup!
  8. #8 Re: Oil change through the dipstick?
    Apr 2009
    Fort Worth TX
    Photoshopped guy.
  9. #9 Re: Oil change through the dipstick?
    i had one of these set ups a while back, used it to change the oil on my boat engine, i/o to getting a pan under the engine was one thing getting back up top with out spilling it was another story.
    i really see no reason to change your cars oils this way but it does have other great uses. like if you over fill the engine with oil, or your trans. and sucking rear end gear oil out of rear ends of rwd cars. power steering pumps, and so on.
    what ever you are trying to suck the fluid from, they always work better when the fluid is hot or at least good and warm.
    i didn't have a electric one, mine was vacuum operated, with a pump like a bike tire pump set deal and a 2 gallon gas can.
    like one of these, worked well for a boat.
    http://www.westmarine.com/webapp/wcs...j#.UAnQ5mGvKSo
  10. #10 Re: Oil change through the dipstick?
    Em I don't see it working right but to each there own...buy your own oil/filter go to jiffy lube or any other oil place pay $12 and have them change it...done.
    04 Comp G.
  11. #11 Re: Oil change through the dipstick?
    Feb 2010
    TN
    This is the way to go have it on all my vehicles Quick Oil Change Plug ยป oilchangesystems.com
  12. #12 Re: Oil change through the dipstick?
    GTP Level Member simbah's Avatar
    Lala land
    Wonder if this system would work for changing the oil in the supercharger? Any opinions.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  13. #13 Re: Oil change through the dipstick?
    to suck out the old sc oil, sure it would work.
  1. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  2. Now that's using your dipstick......
    By alkygto in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 06:38 AM
  3. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
